Oily Turbo.....help needed
An understatment
, took my old turbo off today to put my new one on due to it being a bit smoky....... To find HALF A LITRE yes HALF A LITRE!!! In the bottom hose from metering head to turbo and all the other hoses are soaked with oil, is there anything i should check before i run this new turbo? Cheers pete.
PS its series 2 running gear and std T3
Yeah, but not to the extent i though it would have, i did an oil change a few days before and the oil is just under maximum now so its been seeping for a while before the change, is there anything to check before the new turbo is fired up?
One thing though,make sure you prime the oil pipe before starting it up,have heard this has to be done.
Not sure how to do it though.
Just dont want this one to go pop as it cost me loads of money..... £100
Sounds like you may of overfilled the oil maybe? or turbo seals are just fucked
remeber when priming new turbo aswell as disco'ing the coil, hold the shaft of the turbo with long nose mole grips so it wont turn at all
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
