Advice needed, re. light's in garage
Old Oct 7, 2005 | 08:20 AM
Spiky's Avatar
Spiky
Default Advice needed, re. light's in garage
i have 8 5ft tubes
but not sure what sequence i want them to come on,
i have attached a diagram but just not sure which to have,
basically i dont want all the lights coming on at once, as that just a blantent waste of electric
what's your opinions???
Old Oct 7, 2005 | 08:24 AM
rsnissan's Avatar
rsnissan
option 3 then you can fully light up as much as of the car/garage your working on.
Old Oct 7, 2005 | 08:27 AM
Red16's Avatar
Red16
option 3 is the way, only disadvantage it has is you got more travelling to do to put all the lights on
Old Oct 7, 2005 | 08:28 AM
rsnissan's Avatar
rsnissan
why would he have more traveling to do ? just get a 4 gang swith and stick it near the door
Old Oct 7, 2005 | 08:31 AM
Red16's Avatar
Red16
that is so true can you tell ive just finished nightshift ?
Spiky's Avatar
Spiky
where are your lights switch's in your house??? on the ceiling
as per rsnission, 4 way switch either end of garage
Spiky's Avatar
Spiky
Red16,
yeah you badly need sleep
Old Oct 7, 2005 | 08:32 AM
Red16's Avatar
Red16
Spiky, coont
Old Oct 7, 2005 | 08:33 AM
focusv8's Avatar
focusv8
Switch 1 = Master over all others ( so you can leave the others switched in a particular combination)
Switch 2 = Over the bench or "Dead" end of garage ( most likely to be on and its easier to walk towards a lit area.
Switch 3 = alternate left or right of each of the other three rows
Switch 4 = opposites of switch 3
Have you only got 1 door for access?
Old Oct 7, 2005 | 08:37 AM
rsnissan's Avatar
rsnissan
you want want of those bling clapper switches anyway
Daveyboy's Avatar
Daveyboy
No he has a back door he likes to use frequently
Old Oct 7, 2005 | 08:44 AM
focusv8's Avatar
focusv8
Ahh.. AC/DC lighting.
Old Oct 7, 2005 | 09:24 AM
Spiky's Avatar
Spiky
tosser
Old Oct 7, 2005 | 09:26 AM
Daveyboy's Avatar
Daveyboy
backatcha
Old Oct 7, 2005 | 09:31 AM
KSA-Cossie's Avatar
KSA-Cossie
Option 3 m8.
Old Oct 7, 2005 | 09:37 AM
St3V3_C's Avatar
St3V3_C
option 3, but just 2 switches :
have 1&4 on one switch, and 2&3 on the other
Old Oct 7, 2005 | 09:38 AM
Stealth Bomber's Avatar
Stealth Bomber
...must... stay... awake... must.........................................
Old Oct 7, 2005 | 09:52 AM
Drewman's Avatar
Drewman
u got any updates for your garage?
ie piccies?
Old Oct 7, 2005 | 09:54 AM
Spiky's Avatar
Spiky
ie piccies?
my sig, gives you a clue where to look
Old Oct 7, 2005 | 10:07 AM
focusv8's Avatar
focusv8
Ah, this is the garage with the house in the back garden.
Old Oct 7, 2005 | 10:09 AM
Spiky's Avatar
Spiky
yeah
Old Oct 7, 2005 | 10:13 AM
Drewman's Avatar
Drewman
lmao
didn't notice that!!!
Old Oct 7, 2005 | 10:14 AM
My friend works in a body shop ,they also have the light tubes running down the walls VERY BRIGHT lights up all around the car
Old Oct 7, 2005 | 10:34 AM
david's Avatar
david
If your gonna do all that then make sure you put in some decent dayllight tubes as well
http://www.sadbox.co.uk/products_pri...erproducts.htm
Hi-star is the brightest one.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
Tinshaw
Aug 4, 2015 09:16 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
