alternator light
I've tightend the alternator belt to stop it squeaking but now the battery warning light stays on and flickers slightly. I've checked it all over and it is connected properly, no melted wires etc, it all looks fine. Has my alternator died on me? Anyone else had this before, any help much appreciated. Cheers, Dave.
Checked that one again mate, still no luck. Cleaned it and it's connected well. If it is the alternator im surprised the battery hasn't gone flat yet,. The light is dim at idal then brightens on reving it. Doesn't make sense to me, all I did was tighten the belt.
You might have tighten the belt too much if you have it will fuck the bearing's you should have about half an inch to an inch give in the belt. The alternator still may be fucked even if that battery is not flat just means you have a good battery or the alternator is still puting a bit of a charge into it.
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
jonfoc
16
Sep 11, 2018 05:35 PM
The Enigma
Sep 12, 2015 10:12 PM
