various cossie bits, priced to clear!
Old Oct 1, 2005 | 10:54 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default various cossie bits, priced to clear!
need to get rid of some of my bits and pieces, here goes:
4wd header tank. £20
2x standard 2wd airbox, one has a slightly broken lid, easily repairable. £20
2wd alternator. £40
4wd alternator (milti v). £40
2wd starter. £40
4wd prop. £40
4wd front diff. £40
(unknown make, stainless) 4wd downpipe and centre section. £80
(unknown make, stainless)2wd downpipe and centre section. £80
rear silencer to fit either system, 4" outward rolled. £40
3x 4wd front crossmember with PAS racks. £60 ea
4wd cambelt cover. £30
2wd cambelt cover. £25
2x 4wd turbo heatshields, tatty. £20 ea
4wd loom, ecu with collins chip, 3-bar map sensor, distributor, crank sensor and ignition module. £150
4wd inlet with throttle, ISCV, injectors, regulator and TPS. £50
2wd sump. £25
rocker cover in black. £40
4wd intercooler. £80
4wd gearbox, unlnown condition £80
standard recurculating dump valve with vacuum pipe. £10
tatty saff bootlid, with good spoiler. £40
2wd driveshafts. £20 ea
saff sideskirts, long part only. £10 each
2wd dash surround. £10
4wd dash surround with clock. £25
4wd PAS pump. £30
would prefer if parts were collected, but postage can be arranged.
Old Oct 1, 2005 | 11:42 AM
RScrew69's Avatar
RScrew69
u have pm
Old Oct 1, 2005 | 06:15 PM
AJ Escos's Avatar
AJ Escos
you have pm
Old Oct 3, 2005 | 06:12 PM
AJ Escos's Avatar
AJ Escos
Hi mate any news on which ecu it is?
TrevCos
Aug 22, 2015 06:05 PM
borboyous
Aug 22, 2015 11:17 AM
gcfcos
118
Aug 18, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
