i Cant reverse, gearbox problem? pleaseNO!
Old Sep 30, 2005 | 09:32 AM
Vampire's Avatar
Vampire
Default i Cant reverse, gearbox problem? pleaseNO!
I got my car back from the bodyshop today (pictures up in a few days)
i went to put it in reverse but it wont let me, tried with clutch up and down.
all the other gears work, what could be cousing this?
bit of a nigtmare not being able to reverse!
Old Sep 30, 2005 | 10:40 AM
Scott R's Avatar
Scott R
did they have the gearbox out?
If so the gear box selector may be in the wrong place, could just need a slight turn to allow the shaft into reverse.
Old Sep 30, 2005 | 11:22 AM
Oranoco's Avatar
Oranoco
Sounds like the selector hasn't been set up properly
Old Sep 30, 2005 | 03:48 PM
addiction's Avatar
addiction
yep sounds like a selector problem
Old Sep 30, 2005 | 05:34 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
yep.juss go forwards,backwards is in the past anyways,
p.s.dont go down narrow dead ends!
Old Sep 30, 2005 | 05:35 PM
akito-man's Avatar
akito-man
just turn around in the car,and pretend your reversing!
Old Sep 30, 2005 | 10:17 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Don't worry bout reverse: it's an RST so the floor is prob rotten: just put your feet through the bottom (Flintstones stylie) then pedal away
Or get the selector set-up correctly instead if you really do want it to work
Old Sep 30, 2005 | 10:20 PM
EssexBoyRacer's Avatar
EssexBoyRacer
try holding the clutch down, put it in fourth. Then quickly put the selector into reverse.
if it goes in the clutch isnt disengaging properly - stretched clutch cable for example.
Old Oct 1, 2005 | 11:33 AM
Vampire's Avatar
Vampire
no they didnt have the gearbox outas it was in the bodyshop being sprayed!
all other gears are fine and ive tried 4th and then almmin it into reverse.
do i need a new gearbox or is this fixable?
its just like reverse isnt available ( you cant put it into reverse at all, its blocked off)
Old Oct 1, 2005 | 02:18 PM
NUTS RuS's Avatar
NUTS RuS
Was there a problem before it went into the garage ?
Sounds fixable though
Old Oct 1, 2005 | 11:07 PM
Vampire's Avatar
Vampire
they didnt touch the gear box at the garage, but no the problem wasnt there then!
ive put it into firth driving along today and its making an awful grinding banging noise! gears 1,2,3,4 are al fine tho, what the hell wrong with it!
Old Oct 2, 2005 | 09:16 AM
akito-man's Avatar
akito-man
hey,do they have a forklift truck at the garage?or have they jacked up the car on the linkages,check under for scrapped off oil or scratches on the link bars, i had a rover metro gta (sad to admit ) and it went in to a reputable garage,and they lifted it totally crushing my sills both sides,and then claimed it wasnt them!
cant see how your cars fine one day and fooked the next,av they swapped your box??????????
Old Oct 2, 2005 | 09:41 AM
NUTS RuS's Avatar
NUTS RuS
Whereabouts are you ?
Old Oct 2, 2005 | 02:11 PM
sammy's Avatar
sammy
will it go into reverse without the engine running? if yes, its prob the clutch not disengaging as said above, theres no syncro for reverse, so if the gear wont stop spinning, it cant be engaged.
Old Oct 2, 2005 | 02:50 PM
Oranoco's Avatar
Oranoco
Mine did a rude noise in 5th before breaking. Jammed the box solid
Old Oct 3, 2005 | 09:51 PM
Vampire's Avatar
Vampire
the noise from the box seems to be getting worse, ive tried everything to get the lever into reverse, no luck, running or not running.
what box can i get as a replacement? will a standard 1600 cvh do?
Old Oct 3, 2005 | 10:35 PM
ivorbiggun's Avatar
ivorbiggun
Hello mate
Do your self a favour buy your Haynes manual and set up the selector shaft
properly by losening the pinch bolt and following the instructions/these are different for each different type (S1 and S2) and different model years as well.
I've not been in any RS T that selects/changes gears like mine and indeed haven't found
any Clutch/gear box centre/'specialists' (Ho Ho) that knows how to do this correctly they all seem to do it so it's 'sort of' correct. And indeed most rolling road operators don't know how to select reverse properly as they never have one that works as the good Ford intended any more.
I hope this helps and know that if you do the above (even if, as one the the above experts suggests the linkage has been damaged)it will be better than you've ever hadit.
Luv N huggs
The DR
Old Oct 3, 2005 | 11:05 PM
rsrob's Avatar
rsrob
sounds like the box is fooked
when my box went the first time i had only 3rd and 5th and no reverse
second time it just jammed
Old Oct 5, 2005 | 08:10 AM
akito-man's Avatar
akito-man
so wot was it then?
vampire!
Old Oct 5, 2005 | 09:58 AM
Vampire's Avatar
Vampire
well if my box is fucked and not worth replacing ive got a gargare that said they will fit me a new 1 for 200 quid, what box can i use tho?
will a standard 1.6 cvh boxdo? as an lsd box is so expensive.
Old Oct 5, 2005 | 03:31 PM
akito-man's Avatar
akito-man
dont think so,might get eaten up pretty quick.
Old Oct 7, 2005 | 05:45 PM
Oranoco's Avatar
Oranoco
Don't bodge it you will regret it and ignore the bollocks about the diesel box being tougher, it isn't. Call Bernie at CTS and he will sort you out. His boxes aren't too painfull and are very good. (only box I haven't broken )
www.gearboxman.co.uk
Pay once and pay right. If you can't afford to do it properly now go without the car until you can.
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
gingeRS
Sep 4, 2015 06:29 PM
