4x4 sump,how do you remove it
Old Sep 29, 2005 | 01:27 PM
rob w's Avatar
rob w
Default 4x4 sump,how do you remove it
as topic, sump gasket is leaking and needs replacing.
all advice greatly recieved !!!!!
Old Sep 29, 2005 | 03:07 PM
Dean Saff's Avatar
Dean Saff
They dont have a gasket just sealer.
It is a big nasty job and unless you are good with the spanners it's prob best left to the pro's
Old Sep 29, 2005 | 05:20 PM
TurboFlush's Avatar
TurboFlush
Yes it is a pain in the but. You will have to seperate the motor fromthe crossmember to be able to get the pan out of there.
basiacally make a mess of all the fluids that are the engine bay and atleast a days work.
mine actually had a rubber gasket and the gasket set I got came with a cork gasket. I reused the rubber, but I think I tightened it to much and may have caused some damage. it is hard to get it torqued right. thus better and easier to use the liquid sealant method.
TF
little bram
Sep 21, 2015 02:50 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
hopper350
Sep 4, 2015 12:53 AM
