Pectel Monitor - functions?
Old Sep 28, 2005 | 09:20 AM
DaveEscos's Avatar
DaveEscos
Default Pectel Monitor - functions?
Just got mine back with a brand new patch cable from pectel .. can someone please tell me what it shows you
functions 1-8?
cheers
Old Sep 28, 2005 | 09:24 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I can do better than tell you :
Also, if you got the data link cable added to your loom connection, you can download 90 minutes worth of datalogging to a lap top (I have the software for this if required).
Old Sep 28, 2005 | 09:27 AM
DaveEscos's Avatar
DaveEscos
thanks mike!
and yes, it has the pc serial port in the loom
Old Sep 28, 2005 | 09:32 AM
DaveEscos's Avatar
DaveEscos
oh mike, can you give me any info on what Duty, Co pot, fuel and ign are?
im assuming duty is the injector duty.. but in what parameter? and ign.. in terms of advance? retard?
cheers
Old Sep 28, 2005 | 10:17 AM
Billabong's Avatar
Billabong
Injector duty cycle, no parameter, 0 is unused / 100% is flat out
Only ever seen the ignition in positive values
CO pot doesn't really affect us on P8 as it's not trimmable on the ECU (except certain early versions of P8)
Fuel is fuel delivery in milliseconds
NOTE: boost value is absolute.
I'm still half asleep so forgive me if I've bolloxed any of that up, lol.
Old Sep 28, 2005 | 10:26 AM
DaveEscos's Avatar
DaveEscos
boost absolute? so i have to deduct or add atmospheric pressure?
cheers bill
Old Sep 28, 2005 | 10:31 AM
Mike Rainbird
Caraholic
Deduct .
Old Sep 28, 2005 | 10:34 AM
DaveEscos's Avatar
DaveEscos
what a load of old wank.. what were pectel thinking!
Old Sep 28, 2005 | 11:44 AM
wes's Avatar
wes
Just a thought, it might be because they were trying to get the most out of the amount of logging memory available (memory was quite expensive back then ), if you add a "-" infront of the boost value you are wasting some of the available memory space, so less logging time, however it's quite easy to manipulate these values in excel (once you've downloaded the data) to display the boost as you'd prefer to see it.
Old Sep 28, 2005 | 12:07 PM
Stu @ M Developments's Avatar
PassionFords Creator
Nope, its because all pressure is termed absolute.
Why do you think a 2bar sensor is called a 2bar sensor when it can only see a bar of boost? Same for 3,4 and 5bars. Anyone think, marelli, bosch, lucas and maybe Siemens are also twats who dont have a clue?
The terminology is correct, its ONLY the automotive world that somehow made an arse of it "Boost" is simply pressure over and above atmosphere,a nd atmosphere is approx 1bar. Thus .1bar of boost is actually 1.1bar absolute.
There.
Old Sep 28, 2005 | 01:20 PM
Andreas's Avatar
Andreas
Patch cable? Whats the use of it, can you modify some values within it like the startup message?
Old Sep 28, 2005 | 04:06 PM
Damo V's Avatar
Damo V
Fuel delivery in Miliseconds?? So what does 2.6m equate to??
Old Sep 28, 2005 | 04:12 PM
Sorry Dame, i dont think im quite grasping what your asking as you seem to have answered yourself
That 2.6m is the injectors opening for 2.6ms.
The amount of fuel delivered obviously depends on nozzle size, fuel pressure and inlet tract pressure/depression.
Old Sep 28, 2005 | 04:21 PM
Damo V's Avatar
Damo V
rofl ... so bill shouldve said, fuel is "the length of time injectors are open"
cheers stu
Old Sep 28, 2005 | 07:51 PM
Andreas's Avatar
Andreas
Cmon, whats the patch cable or did Dave mix things up?
Old Sep 28, 2005 | 09:21 PM
MikeR's Avatar
MikeR
There.
It is also deemed that in Diving Thus the largest Pressure change is with in the first 33ft approx because that is double the pressure of the atmospheric pressure at sea level hence the term atmospheres absolute
Slightly of topic but................... i am feeling smart tonight so please forgive a few indulgences
mike
Old Sep 28, 2005 | 09:25 PM
Billabong's Avatar
Billabong
Damo, I did say I was half asleep
I think Dave probably means the cable from the unit to the Pectel loom - Mike R could possibly have sorted that as R&B did mine
Betcha don't have a peak recall facility
Old Sep 28, 2005 | 10:05 PM
DaveEscos's Avatar
DaveEscos
how much!!!!!!!!! ???!!!
Old Sep 28, 2005 | 10:09 PM
Billabong's Avatar
Billabong
You'd have to ask Michael, was all part of the blinding R&B service for moi
....and I had it before Mike
It is actually quite useful, and caught out my bro-in law's over enthusiastic driving once
Dave, what was your power & torque again, can't find your graph's?
Old Sep 28, 2005 | 10:15 PM
DaveEscos's Avatar
DaveEscos
no bill... you seem to have misunderstood..
HOW MUCH!!!!???? do you want to bet that i dont have the peak recall modification/option
'ang on.. ill post the graphs
going for my figures are we??
Old Sep 28, 2005 | 10:19 PM
Billabong's Avatar
Billabong
LOL, two misunderstandings in two nights
So, do you have it or not
No, just interested for comparison sake Mine will probably be slightly less than yours as we're doing something a little different...
Old Sep 28, 2005 | 10:24 PM
DaveEscos's Avatar
DaveEscos
heres the graphs, EXACTLY as harvey and Ahmed printed them
so come on then.. what are you doing??
Old Sep 28, 2005 | 11:41 PM
Billabong's Avatar
Billabong
LMAO
I'll tell you if it works
Old Sep 29, 2005 | 10:37 PM
Billabong's Avatar
Billabong
It worked (much better than I expected!! )
Old Oct 4, 2005 | 08:06 PM
capri-rs's Avatar
capri-rs
MR Rainbird. is this the same stuff that you have???
http://cgi.ebay.com/escort-cosworth-...QQcmdZViewItem
Old Oct 5, 2005 | 12:44 AM
Billabong's Avatar
Billabong
Mike has a Pectel monitor in his car. He also sells SECS monitors that have similar (but not quite as much) functionality.
DixieTheKid
11
Jun 6, 2020 11:20 AM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
Roscopeco
Sep 14, 2015 05:32 PM
