What power/torque do you have for how many psi?
Hello, a small survey to gather all bhp/psi in one topic
I have a Sierra Cosworth and I have just bought the complete kit stage3 (ECU, map, green, actuator...) and I would like to see how much we can to have really with between 15 and 22psi (dyno tested and not estimated)
Thanks
Thanks
when mine came off the rollers i had 285bhp @ 19psi but the turbo was shagged(it only lasted 2 more days, then i had to buy a new one)i also only had a two whhel drive intercooler on
i had a rwd saph 2yr ago it had collins stg3 chip,3"exhaust,t3,greens,3bar,k&n and RWD intercooler running 22psi i got 346bhp on hi specs rollers although the charge temp was high can't remember the tourqe but was a bit lower at about 310
