600 bhp engine for sale!
Dynod at 580bhp/470lb of torque
Built by Harvey Gibbs and mapped by ahmed bayjoo
Accralite low comp pistons
Carrillo H section con rods(proper bling)
Farndon 2.3 crank
Long studded 200 block
WRC tripple layer head gasket
High flow oil pump
Big wing sump
RS 500 inlet manifold
RS500 throttle body
8x green injectors( change these to greys and do over 600bhp)
Nick waples fully polished and ported head(inc bronze guides ect ect)
Secret cams
Vernier Pulleys
2wd exhaust manifold(Modded to take external wastegate)
Tial external wastegate
GT35r turbo with a 1.06 exhaust housing
L8 ecu mapped to this engine
As everyone knows these engines cost big money to build
10k
Farndon 2.3 crank
High flow oil pump
Big wing sump
RS500 throttle body
Secret cams
Vernier Pulleys
10k
This engine has done 2k( 1500 of these miles was done at 12psi(running in) took the car back to Harveys last month to have boost setup and checked, so now running 30psi and flying)
Sorry m8 wont be splitting engine
Im gonna put the car back to standard so there will be plenty of bits coming up for sale
why you selling it?
seems like alot of people selling their big power engines after only doing very low miles....
kinda worring for me seeing as im i the process of running mine in
something i should know guys?
The reason im selling m8 is im after something new
im sure you will be more than happy with your engine as i am with mine
Got to say the buzz you get from a big power cossy is amazing
especially when you take people out in it who have no idea how fast they can be
will be proper scary!
where you get the crank from and whats the stroke.
how could you put one of the most legendary fords ever back to standard. where you get the crank from and whats the stroke
The crank is made by farndon m8 not sure on stroke but Harvey Gibbs knows
awesome...
