s2 bits for sale COME AND GET IT FOR FREE!
due to a MASSIVE change in direction from me im now breaking my track day project,so here goes!all MUST sell!
MFI stg 2 head,needs cam,followers and cam cover to complete,in good condition,valves etc fitted £100
piper 285t2 cam in good condition with a set of piper valve springs £80
kent cams vernier pulley in light anodised blue,looks very nice £30 prov sold
very good condition s1 steering wheel,no tears £20 PROV SOLD
goodridge front brake line braided kit,unused,in box £35 SOLD
powergrip cambelt,unused £5
escort cosworth t28 turbo,very good condition,with uprated actuator £80 SOLD
2x 1.8 zvh bottom ends,both are split, block crank etc all separate,one is originally a fiesta frenzy bottom end,did have accralite pistons(2 need replacing for definite) all the machining work etc has been carried out,includes 1.8 sump and adjusted engine mount,the other requires a sump and engine mount and has machined std pistons to run lower comp ratio,however the block has also received all necessary modifcations to run a cvh head. both need cleaning and rebuilding,but the expansive stuff has been done on both. £150 for the sumped one and £100 for the other
EFI head,needs a damn good clean,got it from philM who says it was kept close to some straw or something,so is very dirty,but would be ok with a clean up!! £20
a set of used koni adjustables, look used as they are,but work fine £75 prov sold
uprated gearbox with diesel ratios and an uprated bearing for higher power £150
group a coil,very good condition,covered approx 5000 miles on my old cossie,and fits nicely in the escort engine bay £25
bayjoo 17psi s2 fuel ecu £150
used 4 paddle clutch (these can be rebuilt) still has a bit of life in it but not much £40
rst exh manifold good condition £15
rst t3 with manifold needs new water connections,good condition,didnt smoke and play is minimal( i DO mean REALLY minimal,no problems) £60 prov sold
EFI inlet manifold with throttle body and tps £20
more bits soon!
if theres anything that may be on a xr3i with a rst engine that you want let me know as its ALL goin and all that is just bits i have lying around!
none of the above include postage,im open to offers for bulk buying etc...but dont go stupid,they all seem fair prices.
cheers.
more bits soon!
cheers.
more!!!!
samco boost hoses in blue £40 PROV SOLD
2wd sierra cosworth intercooler with a metal adaptor pipe to use the original crossover pipe etc... £80
rs1600i dials,good condition £20
inwardly rolled exhaust back box,dunno make,is big enough (about 3 odd inch) bit dented,no apparent cracks £10
straight through exhaust from the turbo back,only box is the back box,which doesnt look quite right as it kinks off at an angle(its made that way,not broken!) and is square,sounds nice,if you dont like the tail pipe may i suggest the above back box?
£80
What sort of difference will i notice using this "2wd sierra cosworth intercooler with a metal adaptor pipe to use the original crossover pipe etc... £80" over a standard rst cooler ?
turbo fits a rst manifold nicely,think the oil lines need extending,and youll need a adaptor pipe to fit to the downpipe on ujah on this site does an adaptor,or you can cut and weld a cosworth down pipe
the 2wd cossie cooler would be a MASSIVE improvement over the std intercooler! and the pipe supplied along with it means you wont have to reverse the charge carrier to fit it! cosworth ics are far superior to rst items,are larger and less likely to break at the same pressures!
im in either wales or gloucester! depends on what time of the week,mon to friday wales(near cardiff) and weekends im in the gloucester area.ill try to sort a pic of the samcos.
i am willing to drive to meet people to deliver these items,but if its a long way to go then ill need some petrol money(dont worry its a 1 litre yaris!!)
standard mfi head bit tappety but otherwise fine complete with inlet manifold and fuel lines £30
std ignition ecu £10
set of 4 c59c plugs,very good for big boost etc,used them on me 34 psi cossie,and they worked fine on me rst engine £10
pair of black corner splitters,for the front bumper,plastic £5
i will try to be on over the weekend to answer any pms but im helping me mrs move so bear with me ill be back on next week for definite!
ok mate i'm interested in...the T28, samcos and the vernier pulley
u still got all of em, can we do a deal on bulk buying lol.
and is the strut brace polished or stainless, if so then i want that aswel
cheers
cheers
Originally Posted by big_wig_074
Ad4m Rst:strut brace is like a shiny silver alloy one fella! will get a pic monday as im away till then!
Originally Posted by Twins
May well need the t3 off you ,will know for deffo on sat ,where abouts are you based as if i need it ,i will drive over to you on the weekend if not to far
Now mate,
Very interested in your exhaust manifolds for s2 if still available.
With turbo or without if you still have one or the other.
As long as the manifold is crack free i'll have it off you mate.
Just let me know ASAP
Thanks Bud.
Thanks Bud.
right then,i have still got: the car itself,minus a bumper,needs that little bit of welding,a stainless exhaust,2 unbuilt zvh engines,a rst engine minus a turbo and ecu that worked fine before i removed the head, the box(rst bottom end and box still fitted) 4x17 inch wheels(bit poor condition but could be refurbed no doubt)in fact,most of the above! i want to get rid,so the first person to arrive with 200 ONO and a trailer gets the lot!theres WAY more than that there! so you could build or sell for spares etc....i dont care,i just need rid!
right then,i need rid of these bits,ALL of them,at once!i will not be letting people take any less than a job lot!so....get your wagons,come and pick EVERYTHING up and youre away,break it for spares,build it up,i dont care! you get a car,an rst engine (head is off) minus a turbo,manifold and fuel ecu,2x zvh bottom ends,a stainless exhaust,a stage 2 head,a 285 t2 cam, a EFI head, a strut brace, a very good condition bucket seat, cambelt,basically,most of what was originally for sale,i now need to get rid of before the end of june,its all near cardiff airport,i will help you load it all up on a trailer and send you on your way with a smile!im getting rid as im moving at the end of june,so come on,this MUST be worth something to someone who wants to build a cheap rst or a trader etc.......
rog
Sep 4, 2015 12:10 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
