oil pressure light on at startup...
Old Sep 16, 2005 | 04:17 PM
andre_k's Avatar
andre_k
Default oil pressure light on at startup...
why, every time i start from cold, or even an hour or 2 after turning it off, does the car splutter for a second or 2, oil light on, then its ok. i have tried disconnecting the cold start valve, and it makes no differance... it only seems to be doing it the last month or so.
Old Sep 16, 2005 | 07:14 PM
andre_k's Avatar
andre_k
bttt
Old Sep 16, 2005 | 07:45 PM
choppa's Avatar
choppa
sounds like the oilways might need a clean out. how often do you change oil? how do you drive your engine? it could be that if you rev the pants off it that the bearings no longer hold the oil pressure like they should. maybe a faulty oil pump, although this is not common. the oil pressure switch in your block operates at about 5 or 6 psi i think, thats bugger all with metal flying round 1000rpm. if your lights on you got a problem. if it goes out after a while somethings on its way out. does your engine knock at all?
Old Sep 21, 2005 | 01:49 PM
andre_k's Avatar
andre_k
the light stays on for only a second, as soon as the light goes off, she stops spluttering. she also seems flat alot of the time, esp on boost, and when i pull away in 1st.
i rarely drive the engine hard, as she gets used daily, and she doesnt knock, well for a cvh shes quiet. oil + filter changed every 3-5k.
hmmmmmmmm... any more ideas please
Old Sep 21, 2005 | 01:50 PM
andre_k's Avatar
andre_k
think ill get her set upp in the next few weeks, ive changed the dizzy recently so the timings prob out... will this cause the spluttering/flatness maybe?
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
