Tools needed to remove steering wheel hub on Sapphire
Old Sep 16, 2005 | 11:19 AM
Stealth Bomber's Avatar
Stealth Bomber
Default Tools needed to remove steering wheel hub on Sapphire
There's a big nut in the middle, which I can remove but it's still stuck fast, was wondering if I needed to get a puller/slide hammer???
Any advice appreciated!
Old Sep 16, 2005 | 12:59 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the big nut is the only thing holding it on. give it a bang on the back with your palms and it should fly off (right into your kisser )
Old Sep 16, 2005 | 05:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
undo the nut to sit's not tight BUT it still needs to be on the threads for around half their length
then, give it some thwumps from behind with the palms of your hands, it may need a few good ones and it'll pop out
the reason you leave the nut on is so that it doesn't break your face when it comes flying off
if you are talking about the non adjustable column, they have a bolt (though it may be the other way around)
Old Sep 17, 2005 | 06:21 PM
john_p_b's Avatar
john_p_b
also put have the ignition key in so the steering lock is off or that'll hold it too!
Old Sep 18, 2005 | 01:29 PM
Stealth Bomber
Cool thanks guys, I'll go hit it hard
JoeyBoyden
Jan 4, 2024 02:36 PM
RockinRein
Aug 19, 2015 07:08 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Bosch
Aug 4, 2015 05:14 PM
fatboy billy
Aug 3, 2015 08:34 AM
