What tools needed to remove a Sapphire steering wheel hub
There's a big nut in the middle, which I can remove but it's still stuck fast, was wondering if I needed to get a puller/slide hammer???
Any advice appreciated!
if u can get the nut undone all u need do i use the flat of your hand on the underside of the steering wheel..hitting opposites sides of the wheel.
it may take a little bit of effort but using hammers & bits can go drastically wrong....
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
