ZETEC TURBO CALIBRA TURBO PISTONS?
Old Sep 15, 2005 | 05:35 PM
yogurt's Avatar
yogurt
Default ZETEC TURBO CALIBRA TURBO PISTONS?
Hi could any 1 tell me if calibra turbo pistons will go straight on to 2.0 zetec rods to do a turbo thanx a lot lads ?
Old Sep 15, 2005 | 05:44 PM
el waffle's Avatar
el waffle
lee @ fusion has done this i think they go straight on because hes using standard rods. just pm him.
Old Sep 15, 2005 | 05:53 PM
yogurt's Avatar
yogurt
thanks el waffle
richm's Avatar
richm
nope, the gudgeon pin is slightly larger, so the little end of the rod needs machining out to suit.
Old Sep 15, 2005 | 06:11 PM
el waffle's Avatar
el waffle
i stand corrected.
Old Sep 15, 2005 | 06:21 PM
yogurt's Avatar
yogurt
thank you richm do you no how much
Old Sep 15, 2005 | 06:24 PM
richm's Avatar
richm
not off the top of my head.. sorry.. afraid i haven't got time to look it up just at the moment
Old Sep 15, 2005 | 07:26 PM
M Brian's Avatar
M Brian
gudgeon pin size can be found in the accralite catalogue I think...
not sure how accurate it is though...
http://www.accralite.com/motorsport2.htm
just an idea.
Old Sep 15, 2005 | 07:31 PM
M Brian's Avatar
M Brian
21mm against 20.638mm from that site.
Old Sep 15, 2005 | 07:34 PM
ON-UJAH's Avatar
ON-UJAH
It's only a few thou but the motor place will do it to the correct fitment anyway. Oil holes need drilling through the piston to provide adequate lubrication to the pin - just copy how the Zetec pistons look. I'm assuming LET pistons are very similar to XE here, as that is what I'd have had to do for my ZVH. I went for Eagle rods and Arias in the end as they were a good price.
Old Sep 15, 2005 | 07:43 PM
M Brian's Avatar
M Brian
out of interest what sort of price are the arias pistons and where is cheap stockist?
Old Sep 15, 2005 | 08:05 PM
LEE-RS's Avatar
LEE-RS
Custom
my mate got this done on his 2.1 ian howel aka area six did it for £100
Old Sep 15, 2005 | 08:34 PM
ON-UJAH's Avatar
ON-UJAH
Arias about 600 quid direct, Eagle a few hundred also direct.
Old Sep 18, 2005 | 07:56 AM
yogurt's Avatar
yogurt
thanks lads
Old Sep 18, 2005 | 08:34 AM
sbd16v's Avatar
sbd16v
let and xe pistons are exactly the same fitment early xe ones are forged just like the let ones late xe ones are cast the only difference is compression let is around 9-1 and xe 10-1 iirc
robnock
21
May 13, 2019 05:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
