Is is just me or are these welded on?
Old Sep 15, 2005 | 04:58 PM
W4SIM's Avatar
W4SIM
Default Is is just me or are these welded on?
Right, trying to get the wing off on a mates Saff and hadnt really noticed it but it seems to be welded on.
If it is then how on earth do you take 1 off?
Wheres the nuts and bolts to it supposed to be? This is the drivers side wing.
Old Sep 15, 2005 | 05:01 PM
Billabong's Avatar
Billabong
Ford wings are generally welded on, Vauxhalls are generally bolted on.
Old Sep 15, 2005 | 05:03 PM
dave cos4x4's Avatar
dave cos4x4
they are welded and you can get a spot weld remover.
Sand the paint off the inner wing were the welds are so you can see them, get a spot weld remover, a drill bit with a sleave around it, when you drill out the weld the sleave cuts out the metal around it so it will lift off.
Easy!
Dave.
Old Sep 15, 2005 | 05:07 PM
Neil S's Avatar
Neil S
Dave, in that case, would there be holes left in the inner wing where the welds had been drilled if the car had had a wing fitted?
(God that was a mouthfull! )
Neil.
Old Sep 15, 2005 | 05:52 PM
focusv8's Avatar
focusv8
Neil.
No the drill only cuts through the outer wing to release it from the inner.
No marks visible once the new outer is fitted
Old Sep 15, 2005 | 06:00 PM
Daveyboy's Avatar
Daveyboy
Anglegrinder.
Old Sep 15, 2005 | 07:41 PM
M Brian's Avatar
M Brian
Originally Posted by Daveyboy
Anglegrinder. :DD:
and a big chisel :cry:
Old Sep 15, 2005 | 07:50 PM
dave cos4x4
there will only be a drill hole where it drills right through.
the outer cutter will only drill the wing and not through to the inner wing...well thats if you don't push to hard.
Dave.
Old Sep 15, 2005 | 09:20 PM
W4SIM's Avatar
W4SIM
WTF ......... so this aint exactly THAT sytraight forward then!!!
Well i would let him get on with it himself but the problem is that i actually need the wing for mine so i cant really balls it up.
I think im almost with it here so il have a proper look and see what i can do.
But for the moment i have an angle grinder and a big chisel? Would these really work? Or would that be madness to a certain extent?
Old Sep 15, 2005 | 09:23 PM
david's Avatar
david
Air chisel and take the wing off in 2 min but fook trying to fit it back on another car
Seriosly though I once tried to fit wings that were new but once fitted to another car I had bought and it was a waste of time TBH so spend the cash and get some new ones
Old Sep 15, 2005 | 09:37 PM
W4SIM's Avatar
W4SIM
Cheers David, that throws a small spanner in the works!
Any 1 know the price of a new wing from Ford???
Old Sep 15, 2005 | 09:59 PM
CozzyBrom's Avatar
CozzyBrom
new ford wing was £80 last time i had one
patten ones around £18
you are a pikey if you rather do all that work than buy a new one
Old Sep 15, 2005 | 10:05 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
use a spot weld drill,takes about 2 minutes to remove.
but i totally agree with brom.
Old Sep 15, 2005 | 10:38 PM
motherhupit's Avatar
motherhupit
The spot weld drill is shaped like a wood drill bit it cuts on the outer edge and a small point in the middle aligns it, i replace a wing and front panel on my old MK2 you can always drill the hole completly out and fill with weld if you'r good enough with the welder, you'll probally need to remove the door aswell to get to the welds this can be a bitch as the door pins wear and are bastards to get out, you'll need someone to hold the door and take the weight of the hinge while you batter the pin out.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
