SERIES 1 . ZETEC TURBO
ENGINE SPEC
2.1 16 VALVE ZETEC
LOW COMP ACCRALITE PISTONS
FARNDON STEEL RODS
ROLLER BEARIN T4
CUSTOM INLET
GREY INJECTORS
DTA ENGINE MANAGMENT.
SECRET SPEC PIPER CAMS.
WILL ADD PICS WHEN COLLECT ENGINE SATURDAY 24-09-05
PRO ALLOY FRONT MOUNT COOLER AND RAD
TAROX 6 POT BRAKES 300 DISCS
REAR DISC CONVERSION.
COMPLETE REBUILD OF SHELL
INCLUDING GAZ ADJUSTABLE COILOVERS ALL ROUND
17'' RSS INOX WHEELS
STRIPPED OUT INTERIOR
6 POINT ROLL CAGE
2 COBRA EVOLUTIONS
FUEL TANK IN BOOT WITH PUMP BATTERY AND SWIRL POT
LIGHTS ARE IN NOW AND THE NEW WIRING LOOM IS ALL WORKING.
NEXT STEP IS TO FIT THE ENGINE, RAD AND COOLER.
2.1 16 VALVE ZETEC
FARNDON STEEL RODS
ROLLER BEARIN T4
CUSTOM INLET
GREY INJECTORS
6 POINT ROLL CAGE
2 COBRA EVOLUTIONS
Yes that the one and it is free, remeber to copy the whole link so it should read something like
[img]title of pic[/img]
Otherwise it wont work, or copy and paste the photobucket thread title in and we should be able to sort it for you.
ill be hoping for 350
the person who is building the engine for me has spent alot of time researching to find out what will work and wont . hopfully i will owe them a big thanks and will be putting down some good times at the pod.
ipicking the engine up next week hopfully the throttle bodies r jenvy 45mm and the pistons are accralite .
it started life out as a 1.1 to sacrilage to destroy a genuine sercies 1 there isnt aenough left as it is.
the blue is kia rally mica blue somthing different.
Originally Posted by throttlebodiedzetecturbo
the only other car that used jenvys woz soy and that made awsome power .
The std EFi manifold + weber TB can flow that, without the need of the above Throttle bodies!
After spending X amount of money on an Engine, Custom manifolds and management system you would expect to see higher figures. IMO
Billy_RS
16
Oct 11, 2025 09:41 PM
