focus gearbox
Old Sep 12, 2005 | 09:43 PM
shaneo100's Avatar
shaneo100
Default focus gearbox
i have a focus 2.0ltr 16valve zetec ghia and am wondering if a st170 gearbox will fit on it what changes will i have to make im also getting the manafold and pipe what bennefits will this make to my car?
Old Sep 12, 2005 | 10:44 PM
Dog's Avatar
Dog
Pretty sure you will need - Gearbox, driveshafts, hubs, gear linkages and cables. IIRC the front cross member may require alteration as the Getrag box is wider than your MTX75. Pretty sure you need to replace the clutch aswell!
You'd be better off sticking with your current box which is more than capable of holding the power!
A ST manifold should see a reasonable hike in power but not enough to warrant a new gearbox
Rich
Old Sep 14, 2005 | 12:13 PM
spudmurphy's Avatar
spudmurphy
The ST manifold is a good addition to the zetec, I have one on my 1.8 and it made quite a bit of difference
To fit it you need the ST manifold, ST cat or decat, and the ST flexi pipe. All this pretty much mates straight to the normal zetec exhaust. I say pretty much as the flange on the ST flexi pipe is rotated about 10 degrees from the non ST one. The best solution I found was to have the flange cut off the non ST system and rewelded to match the ST bits.
Depending on how old your focus is you may also need to block one of the lambda sensor holes, if yours has 2 sensors then I think there may be some modification required as the driveshafts/gearbox on the 1.8's and 2.0's are different to the ST due to the different gearboxes.
To fit the gearbox I think (though I'm not definite) you'll need the gearbox, and driveshafts. The outer ends of the ST shafts may match the 2.0 hubs. If not you'll need them also, though thats no bad thing as you can uprate to ST front brakes which are mint
The problem with fitting the ST 'box is that the speedo take off on the ST box is different to all other foci so your clocks will not read right, if they work at all. You can probably get round this by fitting ST clocks, but I'm not sure how they are tied into the ECU and whether there would be any security system related problems, ie the immobiliser having a paddy
SPUD
Old Oct 4, 2005 | 08:28 PM
shaneo100's Avatar
shaneo100
my focus is a w reg so 2000
whats the rough power hikes ie extra bhp?
please help im feed up with paxos and mg's staying along side me
Bransby
Sep 11, 2015 09:12 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
gingeRS
Sep 4, 2015 06:29 PM
