computer help
Old Sep 9, 2005 | 10:47 PM
BigNige's Avatar
BigNige
Default computer help
Fookking thing
Ok this is the issue my system has slowed down and i want to wipe the lot and reload XP etc
Ok i have taken all i want of the machine and have all i need to rebuild it
i have set the boot sequence to be
IDE CDROM drive then Hard Drive
I put the XP disc in to reboot and format the jobby and it cant see it
WHen i try to explore the Disc not it just stops responding
any thoughts u PC kings
Nige
Old Sep 9, 2005 | 10:48 PM
BigNige's Avatar
BigNige
the discs start spinning but then stop
Im baffled
Please help
Nige
Old Sep 9, 2005 | 10:49 PM
BigNige's Avatar
BigNige
i have the disc in the drive now and try and explore it and it shows as empty nothing at all not the please enter disc just NOthINg
Any help
Old Sep 9, 2005 | 10:54 PM
GrimmeRS2K's Avatar
GrimmeRS2K
go into bios, and disable the hardrive from the start list then re-boot
Old Sep 9, 2005 | 10:56 PM
BigNige's Avatar
BigNige
tried that it sits on a black screen and wont do it
It will then go back into BIOS settings screen
Old Sep 9, 2005 | 11:10 PM
GrimmeRS2K's Avatar
GrimmeRS2K
weird one then, i just selected cdrom drive first then diabled HD
are u sure u dont have the xp upgrade disc
Old Sep 9, 2005 | 11:15 PM
BigNige's Avatar
BigNige
nahh its deffo the one that says this is your operating system that is loaded etc if you need to reinstall use this blah blah
N
Old Sep 9, 2005 | 11:19 PM
GrimmeRS2K's Avatar
GrimmeRS2K
formatted your HD yet?
Old Sep 9, 2005 | 11:21 PM
BigNige's Avatar
BigNige
nope cos then im fooked if i cant get the drives to work etc cos that has the stuff on it
I have tried a restore
I have tried to put music and stuff into the drive to see if it will start but wont
what should the settings be in the BIOS for 2 drives one a CD RW and one a DVD RW
Nige
Old Sep 9, 2005 | 11:23 PM
GrimmeRS2K's Avatar
GrimmeRS2K
what do u mean by settings? boot order?
Old Sep 9, 2005 | 11:24 PM
DaveEscos's Avatar
DaveEscos
maybee you should reformat your hyper x drive ROM system x overload RAM DOS bollocks!
fuck knows, sorry mate!
Old Sep 9, 2005 | 11:29 PM
BigNige's Avatar
BigNige
also do i have to have anything done in the iDE settings in Bios
Old Sep 9, 2005 | 11:30 PM
BigNige's Avatar
BigNige
Dave NICE reply
COCK
But thanks for the BTT
Im gonna have a look at the bIos settings for the drives and only plug ONE of them in
Nige
Old Sep 9, 2005 | 11:33 PM
DaveEscos's Avatar
DaveEscos
yes, exactly what i was going to suggest..
you fucking NEVILLE!
Old Sep 9, 2005 | 11:36 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yeah in your startup list you should have something like this:
1.CDROM (Enabled)
2.Floppy (Enabled)
3.Harddrive (Disabled)
4.DVD (Disabled)
the cd should spin then say 'press any key' to carry on with installation
personally, i format my hard drive first, then configure bios then insert cd
Old Sep 9, 2005 | 11:44 PM
Stu.H's Avatar
Stu.H
sounds like you dont have a proper bootable cd/dvd.
Old Sep 9, 2005 | 11:46 PM
BigNige's Avatar
BigNige
right
Now i try and use any CD or DVD in either of the drives and they wont work WHAT could cause that
This i feel is the root cause of the issue
Dave kiss my ass my Brother in law is Nevville
Old Sep 9, 2005 | 11:57 PM
GrimmeRS2K's Avatar
GrimmeRS2K
so now the cd and dvd isnt working in the operating system or in DOS mode.
in the bios there is a section where it lists all drives, it should be on auto detect and enabled in the boot section, to been shown in windows, its hard to diagnose really, as most bios screens are different
Old Sep 10, 2005 | 12:03 AM
DaveEscos's Avatar
DaveEscos
nige, ifg you have bad BIOS.. which i know you do...
try lynx dry.. africa is my favourate fragrance
Old Sep 10, 2005 | 12:05 AM
Stu.H's Avatar
Stu.H
lol
Old Sep 10, 2005 | 12:12 AM
BigNige's Avatar
BigNige
dave = Bell End
LOL
Old Sep 10, 2005 | 12:13 AM
DaveEscos's Avatar
DaveEscos
Old Sep 10, 2005 | 12:24 AM
BigNige's Avatar
BigNige
Ok
I can see both the drives in BIOS this is what it says
Primary Master = Hard Drive
Primary Slave = OFF
Secondary Master = CDRW
Secondary Slave = DVD RW (jumpers are set accordingly too)
IDE Drive UDMA = OFF
Is this ok so far
##Then in XP operating system
I can see both of the drives and they both have discs in but neither show ANYTHING when you try and look at them eitehr by double click or right click Search or right click explore
Nige
Old Sep 10, 2005 | 12:34 AM
tonyk's Avatar
tonyk
Is it a genuine xp disc? If its just a copy it may have become corrupt or may not be a bootable version. If you have any other discs you know are bootable try those.
Old Sep 10, 2005 | 12:35 AM
BigNige's Avatar
BigNige
genuine disc and first generatiin copy
The issue is the fact that the drives wont do anything at all
How do i sort that
n
Old Sep 10, 2005 | 12:40 AM
tonyk's Avatar
tonyk
Try swapping the ide ribbon cables over and see if that makes a difference, incase its a fault with cable. Also try with just one drive connected. It may also be an idea to reset the bios as a last resort.
Old Sep 10, 2005 | 12:41 AM
Paul_RS's Avatar
Paul_RS
You could try resetting the BIOS back to standard settings, thentry running the XP disc again. Another thing to check is the actual connections inside the case - are they all correct?
Old Sep 10, 2005 | 12:43 AM
Paul_RS's Avatar
Paul_RS
lol great minds think alike!!!!
Old Sep 10, 2005 | 12:44 AM
BigNige's Avatar
BigNige
tony i have just downloaded and installed the latest BIOS flash from Dell and stuck that in , The cables seem to be fine adn have checked them this is the image i get when looking at ANY disc this one is for REM Greatest Hits
any thoughts
Old Sep 10, 2005 | 12:45 AM
Paul_RS's Avatar
Paul_RS
Hmmmm well the computer is seeing the drive, its just not reading the disc correctly.... i'm stumped now
Old Sep 10, 2005 | 12:56 AM
BigNige's Avatar
BigNige
well just to confuse matters more
If i put a DVD in the DVD RW it sees it and reads it OK
Heres the image but any other type ie CD , DAta , Software it doesnt
Whats that about
Old Sep 10, 2005 | 01:12 AM
Paul_RS's Avatar
Paul_RS
Strangenessss. Just to be clear about things - if you put the XP disc in a reboot, does it give you the option to 'boot from disc'??
Old Sep 10, 2005 | 01:19 AM
Dan B's Avatar
Dan B
Get hold of some XP boot disks and try those instead?
I'd normally suggest http://www.bootdisk.com, but I'm pretty sure they've started charging for XP boot-disks now!
Old Sep 10, 2005 | 01:32 AM
BigNige's Avatar
BigNige
rS nutter nope it will just hang
NIge
Old Sep 10, 2005 | 10:49 AM
tonyk's Avatar
tonyk
Nige when your trying to boot from the xp disc you have make sure the cd drive is disconnected on both power and ide leads. Some bios will only let you boot from the drive that is on the top end of the cable. If this drive is duff it could be locking the system up.
The last thing I would try is swapping the hard drive onto the dvd drives ide channel, this would determine if the board is duff as the hard drive wouldnt boot now.
Old Sep 10, 2005 | 11:11 AM
motherhupit's Avatar
motherhupit
If it doesn't read the disc when in xp even though xp detects the drive, then the drive is probally totalled.
They can be tempramental, like all dam computers
Try swapping over the IDE cables, try didfferent jumper setting like putting your cd drive on the same cable as the hard-drive (primary) and then change the jumpers accurdenly, try using the cable select jumper on any drive thats on its own on a cable.
If all else fails try taking the cd drive apart and clean up the laser lens and pull all the tiny cable apart and put them back somtimes they can get bad connections, be carfull though these are easy to break and easy to rip the cables, this might fix it i'ved fixed lots of things, that the cables come loose on.
Old Sep 10, 2005 | 12:08 PM
Redkop's Avatar
Redkop
You can use either the CD or the DVD drive for installing.
Old Sep 10, 2005 | 01:56 PM
Eagle's Avatar
Eagle
Super Moderator
nige you have a pm ...
AJC
Oct 1, 2015 06:47 PM
Kam B
Sep 24, 2015 10:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
