Fuel Line Ruptured - Best Fix?
Old Sep 9, 2005 | 09:04 AM
MWF's Avatar
MWF
Default Fuel Line Ruptured - Best Fix?
Fired up my 4i the other day for the first time in 12 months and it wee'd fuel everywhere. (Tony Mannock warned me about this 18 months ago when I had the car inspected)
The problem is on my 4i you have
little metal pipe < rubber section with jubilee clips > little metal pipe
It's the rubber section that's gone.
I guess I could just buy some replacement pipe, two new clips and replace it. But I aren't sure if that's the best fix? I do have an RS500 fuel line piece on my XR4x4 I could swap it over but I aren't too sure how you get that off.
Am I OK replicating what's there or is it a bodge not worth re-bodging?
Old Sep 9, 2005 | 09:07 AM
Damo V's Avatar
Damo V
you could as you say just fit new rubber pipe if its been on there 20 years and has been fine till now....
OR you could get some of those plastic compresion joint things clean up the 2 metal lines, put then on the old metal hose then add another bit of plastic or metal hose in between
Old Sep 9, 2005 | 09:09 AM
MWF's Avatar
MWF
Interesting, not heard of the plastic pieces, thanks for the advice!
Old Sep 9, 2005 | 09:32 AM
Damo V's Avatar
Damo V
like what plummers use now on plastic tubing or in pubs on the plastic beer lines, but smaller
Old Sep 9, 2005 | 09:35 AM
Jim Galbally's Avatar
Jim Galbally
why dont you wanna replace it with another bit of fuelhose? is it suposed to be like that, or is it from a previous bodge?
MWF's Avatar
MWF
Thanks I'll try and hunt some out
Old Sep 9, 2005 | 09:47 AM
MWF's Avatar
MWF
I don't know the answer to that Jim. On my XR4x4 the fuel filter is in a totally different place but had a similar rubber hose bodge. On my 4i the fuel filter is sitting horizontally on the inside of the front near side arch. On my 4x4 it's vertical and on the front valance. From pics I have seen on other cars they are all over the place so I don't know where it should be as standard.
Also since I have a turbo conversion planned I don't want to do anything that's going to compromise safety so moving the filter might be an option. Cost isn't an issue either so I would rather do it once and do it right so to speak.
Old Sep 9, 2005 | 09:51 AM
Damo V's Avatar
Damo V
-6 Aeroquip from the tank to the filter then from the filter to fuel rail, then reg to tank
good 200 quids worth but it aint gonna leak
Old Sep 9, 2005 | 09:54 AM
MWF's Avatar
MWF
Thanks for the advice
Old Sep 9, 2005 | 10:26 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
It's not supposed to be like that jim some one bodged it before lucky it has lasted this long it was more likely to have done a lamb chop that not lol
Old Sep 9, 2005 | 10:33 AM
MWF's Avatar
MWF
I think I'm going to inspect the aeroquip bits I have on the 4x4 and see what looks in good enough condition to swap across. I don't like the location of the fuel filter in relation to were the turbo will be.
Old Sep 9, 2005 | 11:15 AM
Jim Galbally
MWF, on the 2.9 TT cars you move the fuelfilter.i assume the 2.8s are the same (but ive never seen a manual)
Old Sep 9, 2005 | 11:21 AM
MWF's Avatar
MWF
Cheers Jim, like I say I'm not sure if mine is in the standard 4i position or not. The position on my 4x4 seems a sensible one to copy.
Old Sep 9, 2005 | 01:08 PM
Jim Galbally
4i is joined to the side of the airbox i think (or at least near it)
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
kevin36
Sep 8, 2015 12:23 PM
