S1 & S2 Know-it-all's!
Old Sep 9, 2005 | 12:58 AM
BillyCabrio's Avatar
BillyCabrio
Default S1 & S2 Know-it-all's!
Following on from this....
https://passionford.com/forum/viewto...029827#2029827
The car is finally turning over but won't fire. There is no Negative from the coil and no spark.
On connecting a temp link between -neg on the coil and the -neg on the batt, still no spark.
And on the No2 ignition turn, the Amal valve makes a loud clicking noise while the pump is priming
I have connected up the earth strap from the rear lifting eye to inner wing, should there be one from the gearbox to chassis?
Also.............
No.1 Is for what exactly?
No.2 Main +Posi Battery Cable
No.3 Crank trigger wire?
Dunno why but No's 1 and 3 are round the other way on my starter motor Anyone confirm their all correct?
So any thoughts on the no spark situation?
Cheers in advance guys Oh and a thanks to Damo for the text helpline
Old Sep 9, 2005 | 01:00 AM
BillyCabrio
Anyone live in Kent or Essex fancy coming over to help me suss this mess out?
Someone who knows what their doing more than i do please
Old Sep 9, 2005 | 01:02 AM
BillyCabrio
Oh and one other thing lol.....
I got a spare wire that comes up in the loom from behind the passenger headlamp, it has 2 wires - 1 is brown and black the other is just brown.
Any ideas on that?
Sorry i'll leave it alone now
Old Sep 9, 2005 | 01:18 AM
xr4x4rs's Avatar
xr4x4rs
1 not needed
2 main power
3 crank wire
what was the cause of it not cranking over?
sounds like an immobiliser problem
that other connector with them wires could be amal valve wiring?
but wont know till i c a pick
Old Sep 9, 2005 | 08:48 AM
BillyCabrio
xr4x4rs,
Heres the wire, its a phone picture mate - but is defo not for the Amal valve as it wont fit and is live.
Old Sep 9, 2005 | 09:04 AM
Damo V's Avatar
Damo V
You sure that aint the sidelight plug??
Old Sep 9, 2005 | 09:05 AM
Damo V's Avatar
Damo V
paul are you going over the garage today?
Old Sep 9, 2005 | 09:16 AM
Westy's Avatar
Westy
that picture that you took on your phone.. I have the exact same thing, which is also disconnected..
I know its probably no help, but mine runs fine with it like that
Old Sep 9, 2005 | 05:42 PM
Damo V's Avatar
Damo V
Originally Posted by BillyCabrio
xr4x4rs,
This is the fan overide picture.
WHAT we need to know is, should there be a perm earth at the coil with IGN on??? as there isnt one....
Also Anyone got an engine bay pic so I can see what wires go where on the battery?? Just to confirm a couuple of things
Old Sep 9, 2005 | 05:47 PM
xr4x4rs's Avatar
xr4x4rs
i should imagine there should be a perm earth at the coil as it wouldnt spark but not to sure
battery wise there should be two black cables that look like neg but are positive fuseable wire it is
then just the main power
Old Sep 9, 2005 | 05:51 PM
Damo V's Avatar
Damo V
the battery wires are right it was the brown wires I wasnt sure about but they are on the earth side, so thats fine, the fusable links yeah they on fine, Im fairly certain the coil should have perm NEG, with IGN on, I personally think the ecu isnt getting IGN live, so we need pin numbers for ecu ie which are IGN live etc...
Paul change thread title mate, "No spark ecu pinouts neededet etc"
Old Sep 9, 2005 | 06:05 PM
Al Bags's Avatar
Al Bags
Hi ...
If I remember right ... The Brown + Brown/Black is an Air Temp Sensor connection, which goes to the Ignition Module.
GrimmeRS2K's Avatar
GrimmeRS2K
you are right, the coil negative wire, should always be negative with ING on to clear that up
Old Sep 9, 2005 | 06:06 PM
Damo V's Avatar
Damo V
Originally Posted by Al Bags
Hi ...
no it is a fan overide plug
Old Sep 9, 2005 | 06:08 PM
Damo V's Avatar
Damo V
grimmeRST,
Cheers for that mate, right paul there is your problem, check the ecu has IGN live IMO
Old Sep 9, 2005 | 06:14 PM
Al Bags's Avatar
Al Bags
OK .. I just checked .. We did wire the AIT sensor up with those colours on K and KE Jetronic Injection.
Make of it what you will then
Old Sep 9, 2005 | 06:22 PM
Damo V's Avatar
Damo V
yeah they probably lives and earths everywhere, but these are THICK wires, ie heavy current....
Old Sep 9, 2005 | 07:10 PM
BillyCabrio
No.1 Are the 2 wires (both brown) Damo thinks should be attached to the Positive, but were both not sure
Are the only wires on the Negative the 1 thick one??
Old Sep 9, 2005 | 07:13 PM
BillyCabrio
Can someone with a S1 confirm that these wires are correct as you can see another plug has been fixed on, but were not 100% sure the connections are correct
Just need to know what colour wire goes to + and 0 and -
Old Sep 9, 2005 | 07:14 PM
BillyCabrio
We also need a break down of the pins in the ECU and the fuel ECU, as we need to trace back power etc.....
Old Sep 9, 2005 | 10:37 PM
GrimmeRS2K's Avatar
GrimmeRS2K
have u had any luck yet with the ecu pins?
Old Sep 9, 2005 | 11:12 PM
GrimmeRS2K's Avatar
GrimmeRS2K
check pin 13 for power with IGN on.
Old Sep 10, 2005 | 08:52 AM
Lee Reynolds's Avatar
Lee Reynolds
Not sure if this helps but these are the battery wires
Note the big red sheafed one to pos has 2 or 3 black wires in it iirc!
Old Sep 10, 2005 | 09:37 AM
Damo V's Avatar
Damo V
Paul, your battery wires are right, dont worry about that, I am fairly sure your dizzy phase wires are right but as paul says, if anyone knows, which colour wires are + 0 - that would be a great help just to confirm,
Paul as per grimme... PIN 13 should be live with IGN on, let me know how you get on paul I'll be on my Mob
Old Sep 10, 2005 | 11:26 AM
BillyCabrio
Thanks for all your help chaps! Specially you Damo
I let you know how i get on, so expect a phone call
Old Sep 10, 2005 | 09:18 PM
BillyCabrio
Anyone help with this?
Old Sep 12, 2005 | 07:02 AM
zvhturbo's Avatar
zvhturbo
Hi ...
Thats a side light plug.
Paul, i have a ford workshop manual for the RS, which has wiring diagrams for the ecu's.
I'm also pretty good with wiring if you need me to pop over the weekend.
Matt.
Old Sep 12, 2005 | 11:27 AM
Damo V's Avatar
Damo V
Damo V,
_________________
Matt, I said that 3 daqys ago... get with the program
It isnt it IS somewhere to plug a Fan overide switch FACT
Besides we managed to get it running,
problems cured included
dodgy dizzy, not sending out a phase signal
the plug which goes onto the dizzy, had the wires the wrong way round,
the plug which goes to the dizzy was the wrong plug LOL
we managed to get it running for about 2mins, then it died, felt like it ran out of petrol, buggered about with it constantly for hours, I am fairly sure its now down to a dodgy metering unit..... which is going to be changed today....
Big thanks to Pauls mate Liam who came along in his S1 and let us rob a few bits off it
Old Sep 12, 2005 | 09:03 PM
BillyCabrio
Hi ...
Matt.
Nope both wrong
mk3's never had a fan over ride wire, i found out today that it is actually..................
The fan thermostate switch wire. Duh, i should of known
Matt thanks for the loan of yourself but, i think you may not be needed. Although as of tonight it still aint running properly.
We managed to get it going for about 5-7 minutes today, running nicer than yesterday.
But it just wouldn't idle properly, almost sounds as if its missing or the timing is well out. The time it did start today the timing on the dizzy was fully advanced.
The crank pully and cam pully are both correct with the timing and when all is TDC the rotor arm is in the correct place.
Its really weird
Also the battery is on its last legs with holding charge, so its on charge overnight again tonight. But a new one would prob help quite a bit.
On initial cranking there is a nice big bright spark, but 1 to 2 seconds later its a weak spark - could be the problem, but its a real puzzle.
Any thoughts?
Old Sep 12, 2005 | 09:13 PM
BillyCabrio
Yeah Oooops
Thanks god for cossie management eh Damo
Old Sep 12, 2005 | 10:37 PM
BillyCabrio
Old Sep 13, 2005 | 08:23 PM
BillyCabrio
Anyone got any ideas?
Old Sep 13, 2005 | 10:04 PM
GrimmeRS2K's Avatar
GrimmeRS2K
so the problem with the car is has a good spark for a few seconds then a crap one?
Old Sep 13, 2005 | 10:07 PM
Lee Reynolds
cranking takes a lot of battery power...if its on its lasts legs that may be why the spark goes weak
Old Sep 13, 2005 | 10:12 PM
BillyCabrio
Basically, yeah. Any thoughts?
Trying to sort a new one now.
Old Sep 13, 2005 | 10:15 PM
Lee Reynolds
let us know how ya get on mate. Have you tried the spark by just using jump leads form ya other car to the cabby?
Old Sep 13, 2005 | 10:17 PM
BillyCabrio
Will do Lee, I wanna try that but the cabbie is facing the wrong way around
Old Sep 13, 2005 | 10:18 PM
Lee Reynolds
doh
Old Sep 13, 2005 | 10:20 PM
GrimmeRS2K's Avatar
GrimmeRS2K
deffo try the battery as stated, will help
failing that, are you sure the fueling system is ok and working correctly?.
Havent got any air leaks anywhere in the breathers, do u run a dumpvalve, if so try taking it off
All the wiring ok now?
Old Sep 15, 2005 | 12:51 PM
BillyCabrio
grimmeRST,
Going to try and turn the cabbie around to get some jump leads on there for the time being. The batt thats on there is ok, but we are killing it on the amount of times weve tried starting it now.
No air leaks.... that i know off. Got all Roose hoses on there now.
Dump valve Err no PMSL.
And as far as i know, wiring is ok. Alex-ZVH thinks he is upto the challenge, so we'll see.
Red16
16
Sep 30, 2009 07:44 PM
SteveH
20
Jan 20, 2009 07:16 AM
Stu.H
17
Mar 27, 2007 03:41 PM
Stu @ M Developments
30
Jan 19, 2006 11:55 AM
