charge cooler for s2 ne1 made 1 with a standard intercooler
Old Sep 7, 2005 | 07:28 PM
white cab's Avatar
white cab
Default charge cooler for s2 ne1 made 1 with a standard intercooler
just making one now but put the plastic caps back on which i will bond together with apoxy resin and strap it just to make sure there are no leaks.
has any one done this and if so what were the results ?
Old Sep 8, 2005 | 12:13 PM
JesseT's Avatar
JesseT
I've been thinking of this too a few times. It would be a solution not completely blocking the radiator. I'm just worried how much the standard S1 or S2 IC flows.
Old Sep 8, 2005 | 01:04 PM
Spiky's Avatar
Spiky
why not just buy my complete charge cooler system, which is from an esc cos
Old Sep 8, 2005 | 01:33 PM
Steven_RW's Avatar
Steven_RW
I built a homemade chargecooler back in the day. Used a 2wd cossie intercooler for the task. Worked really well. Only issue is getting the water cooled back down and back into the chargecooler as quickly as possible.
Not sure what the std intecooler will flow. I've seen 180 odd at the wheels usingtwo std intercoolers flowing out of one in to the other in line. So thats not too bad.
RW
Old Sep 8, 2005 | 02:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
using a device originally designed for air to air to heat trnasfer is not necessarily th ebest way of doing it, but i suppose that it's cheap and readily available
Old Sep 9, 2005 | 08:18 PM
white cab's Avatar
white cab
if you think about it your house boiler has a heat exchanger about the same size if not smaller than a s2 ic and look at the heat that dissipates !
the bigger the rad and the more water you can cool the better the issue is not having a twin pass through the ic to cool the air enough.
i will post some pics l8r to show the progress
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Old ford
Jul 31, 2015 06:50 AM
