How unsafe is it to run a car in gear on axle stands?
Old Sep 7, 2005 | 02:03 PM
avengerpenguin's Avatar
avengerpenguin
Default How unsafe is it to run a car in gear on axle stands?
Think the clutch on my escort may have stuck and have been advised to start it in gear, and run it with the clucth peddle down to try and free it up.
Question is....is it reasonably safe to put the car on stands just off the floor and run it in the garage?
Old Sep 7, 2005 | 02:06 PM
FordFans's Avatar
FordFans
Should be safe enough on axle stands mate, just make sure they're well secure before doing anything though
Old Sep 7, 2005 | 03:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
when i bent my old mk4 escort in half i had it up on stands - in the mud lol and held it on the limiter in 5th for a few mins untill my mum had a go at me
had the fooker off the clock at about 160 too pmsl
ps, i didnt even think of the safety issues back then, but if it were to fall off it will only stall
Old Sep 7, 2005 | 03:23 PM
John Laverick's Avatar
John Laverick
I do it with mine all the time...shouldn't be problem
Old Sep 7, 2005 | 03:25 PM
adamS2RST's Avatar
adamS2RST
I worry about starting the car on stands let alone running in gear As said should be ok I guess make sure they are as safe as can be
Old Sep 7, 2005 | 04:18 PM
BillyCabrio's Avatar
BillyCabrio
You only need the front up in the air after all, just make sure the back wheels are nice and chocked.
Old Sep 7, 2005 | 04:23 PM
Damo V's Avatar
Damo V
PMSL... you trying to send him into space
you know what happens when one assume's something dont you paul
Old Sep 7, 2005 | 04:50 PM
Spax's Avatar
Spax
you know what happens when one assume's something dont you Paul
LOL I have visions of it launching into the air
I did this on my old Sierra Saph 1.8...it hit 150 in 3rd gear lol, Dangerous tho
Old Sep 7, 2005 | 04:59 PM
NUTS RuS's Avatar
NUTS RuS
I do it at every event in the morning to warm up the gearbox oil and brakes before setting off.
Old Sep 7, 2005 | 05:23 PM
avengerpenguin
Done it, no problems but didnt fix the problem so the box is coming back out.
BillyCabrio, thanks for the advice, however I am glad I didnt put the front in the air and leave the back down.
Old Sep 7, 2005 | 05:27 PM
Eagle's Avatar
Eagle
Super Moderator
i had my 4wd cossie up in the air about 5 inches off the 4 poster ramp touching 150
even done it on the 2 poster ramp at 150+
only when you think about what could happen you think .. hmmm not one of my better ideas
Old Sep 7, 2005 | 05:31 PM
Rhys's Avatar
Rhys
Just ideling will be fine! but i wouldint like to do 150mph run in it
Old Sep 7, 2005 | 05:33 PM
Eagle's Avatar
Eagle
Super Moderator
chicken
Not a problem if its securely on the stands, there isnt enough vibration or torque reaction to shake it off a decent set of stands.
video it just in case though, at least yuo will get some cash back fromyou've been framed if it does go wrong
Old Sep 7, 2005 | 07:26 PM
avengerpenguin
Going to change the clutch now, anyone know if a 2wd saff clutch will fit a pinto engine and box?
Chip, I only found out last weekend who you are
Not Glass Eye or anything like that before someone says anything.
Old Sep 7, 2005 | 07:30 PM
The Sludge's Avatar
The Sludge
garibaldi
sounds dodgy on stands id be scared to fook
"ashes to ashes , dust to dust"
Old Sep 7, 2005 | 07:34 PM
BM08's Avatar
BM08
a 1.8 sierra doing 150 in 3rd?? keep smoking that shit mate!!
avengerpenguin
It was a bit dodgy, due to the fact that the clutch is stuck so I had to start it in gear and if it had come off I couldnt dip the clutch
Old Sep 7, 2005 | 07:38 PM
warleydaddy's Avatar
warleydaddy
I had my old saff up to about 130mph on the ramp at the zoo..
Pete...
Old Sep 7, 2005 | 07:53 PM
Rs Baz's Avatar
Rs Baz
i remember my clutch was stuck on a car i had some time ago
i put it in gear and drove it around like that for about 10 mins it
went with a big bang and it was freed off try that.
ive put a car on 2 jacks and let it run in gear up to 50 mph
Old Sep 7, 2005 | 09:51 PM
BillyCabrio
Sorry, i over looked that fact that it was a taxi we were talking about
I'm with NUTS RuS tho, FWD
Old Sep 7, 2005 | 10:14 PM
Damo V's Avatar
Damo V
Wrong again
Old Sep 7, 2005 | 10:19 PM
BillyCabrio
Ok, ok a rwd Escort
Old Sep 7, 2005 | 11:47 PM
stevieturbo's Avatar
stevieturbo
C**t
AFAIK, a cossie flywheel is different
A Cossie clutch will not fit a normal 2.0 Pinto flywheel, and Im pretty sure its too large for the regular 5 speeds bellhousing too.
Old Sep 8, 2005 | 12:12 PM
CosRush's Avatar
CosRush
Indeed, the Pinto crank has (iirc) 7 flywheel mounting bolts whereas the cossie has 9...............
Plus ive ran mine on axle stands in the garage loads of times.....no probs.
Old Sep 8, 2005 | 12:54 PM
Andreas's Avatar
Andreas
Some ppl moan about the cooling fans at rolling road not being up to the job while some ppl run their cars flat out on axle stands without any cooling at all.
Old Sep 8, 2005 | 04:42 PM
stevieturbo
C**t
Although, on stands the engine is under no load.
Aug 8, 2015 07:12 AM
41
Aug 7, 2015 08:58 PM
knight19770
Aug 4, 2015 12:36 PM
RIB1122
Aug 3, 2015 09:20 AM
Old ford
Jul 31, 2015 06:50 AM
