4wd to 2wd....
Old Sep 7, 2005 | 12:47 PM
DonkeyKong's Avatar
DonkeyKong
Default 4wd to 2wd....
2.9 xr4x4,anyone know how easy to convert to 2 wheel drive?whats needed etc?cheers!
Old Sep 7, 2005 | 06:35 PM
sailorbob's Avatar
sailorbob
To start the list off;
2wd front hubs
2wd gearbox
Probably 2wd propshaft
Exhaust might need tweaking
I'm sure someone with more idea will add to the list (or correct me!)
Old Sep 8, 2005 | 05:20 PM
dojj's Avatar
dojj
Resident Wrestling Legend
sump
gearbox
prop
gearbox mount
everything else can stay as it is if you ditch the driveshafts and prop you won't need to change anything else
if you DO decide to go with the 2wd stuff you'll need to change the hubs and struats and arb and crossmember and steering rack and intermidiate shaft too, lots of work when you can grab a granny sump and hunt around for a front casing for a 2wd gearbox to bolt your V6 front casing too
Old Sep 11, 2005 | 03:15 PM
cossy abuser's Avatar
cossy abuser
why not leave the front diff in place and shafts, just replace the box and prop with a 2wd item then if you want 4x4 again its all there.
Old Sep 11, 2005 | 05:06 PM
dojj's Avatar
dojj
how would he keep the crap out of the diff then?
Old Sep 11, 2005 | 07:17 PM
cossy abuser
there is a flange on the diff that the small prop bolts too, if you leave the drive shafts in, you won't get any crap into the diff. All you are doing is removing the small front prop which will not let ANY crap into the diff
Old Sep 12, 2005 | 11:10 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that'll do wonders for your rolling resistance / fuel consumption it's not like fuel is expensive these days is it?
Old Sep 12, 2005 | 03:02 PM
cossy abuser
he didn't ask for the most fuel efficient way of doing it.
he just asked what should be changed
dojj
28
Sep 11, 2015 10:00 PM
focus2351
Sep 9, 2015 09:33 PM
Ridgey
Aug 30, 2015 08:37 AM
Harryh24
Aug 11, 2015 07:48 PM
lockie
Jul 31, 2015 10:03 PM
