Focus 1.8 Zetec. (standard engine) can a dump valve be fited
Old Sep 5, 2005 | 12:20 PM
s34ton's Avatar
s34ton
Default Focus 1.8 Zetec. (standard engine) can a dump valve be fited
hi. don't know much about engines. want a dump valve for my focus 1.8 zetec. told you have to fit the dump valve to a turbo? is this the case?
Old Sep 5, 2005 | 12:30 PM
Willow's Avatar
Willow
That is indeed the case - they are used to vent excess boost generated by the turbo.
Old Sep 5, 2005 | 07:38 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
i cant believe this question still gets asked
Old Sep 10, 2005 | 10:21 AM
s34ton's Avatar
s34ton
the guy that left the message "i cant believe this still gets asked" is a bit of a ignorant tit. not everyone knows about engines, just like he doesn't know how to make friends because he has time to write things like that!!
Old Sep 11, 2005 | 10:09 PM
Dog's Avatar
Dog
Says he that had to ask about a DV on a NA motor!
Clicky here, this should do the trick for you!
Rich
Old Oct 20, 2005 | 09:34 AM
Jables_09's Avatar
Jables_09
if its just the the sound of a dump valve your after, you can get fake ones. they dont have any purpose apart from the sound. check the adverts in max power, redline etc.
Old Oct 28, 2005 | 04:20 PM
filthyrichie's Avatar
filthyrichie
company called sagem edv do a sym they just improved it we fitted a mk1 version a bit crap really but i recon this will be better
Old Nov 1, 2005 | 06:52 PM
shaneo100's Avatar
shaneo100
theres a place in ipswich called mjs they have this box that u hide where you like and some how the box knows when you change gear and gives the pssst noise that you may be after i will try and find an email address or telephone number for u ok
Old Dec 19, 2005 | 09:51 PM
Rick205's Avatar
Rick205
My god this thead is shocking, why are people even humouring something as retarded as a "fake" dumpvalve
You dont need a vast amount of knowlege regarding engines, just common sense!
Jeeesus.
manuel boeckx
13
Oct 3, 2015 02:29 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
taylora1409
Aug 12, 2015 12:06 PM
rsstav
Aug 11, 2015 04:22 AM
