head copper gasket
Old Sep 4, 2005 | 04:56 PM
kikk0's Avatar
kikk0
Default head copper gasket
hello!
I just bought a head copper gasket for my sierra is turbo.
Does anyone have experience in how to get the gasket 100% sealed?
Someone told me to heat the gasket before i assemble it, but is there a special sealant I shout use?
thanks for answering
Frode
Old Sep 4, 2005 | 05:56 PM
Dave Henshall's Avatar
Dave Henshall
not hear of a copper head gasket, other than a de-compression plate, are you sure its a copper head gasket and not a head gasket meant for coopers rings...?
Old Sep 4, 2005 | 06:29 PM
kikk0's Avatar
kikk0
no it's a "stand alone" gasket made of pure copper. It's not a de-compression plate
Old Sep 4, 2005 | 07:26 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hey m8 i am using d comp plate on zetec turbo conversion the head gasket is the same thing but lots more work,i think u have to get both surfaces skimed block&head then use a small amount of some h/t sealent(eg curil t or other)
when doing zt conversion i only use on plate to block but i still use head gasket to seal block to head,if in dought give feriday engineering a call on01785621710 tomorrow i hope this helps
Old Sep 4, 2005 | 08:00 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Where did you get the gasket from ? Surely they would be able to advise you on best method for fitting
Old Sep 7, 2005 | 06:01 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
update
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
pie-face
Sep 15, 2015 10:43 AM
