abs
Old Sep 4, 2005 | 04:02 PM
smudge09's Avatar
smudge09
Default abs
abs is doing my head in the light stays on ive had the sensors checked all ok but its still on i get feed back throught the pedal as i brake sometimes (like somthing pushing /grinding back) ive changed the abs pump/resivour still the same problem i read on another site that wheel size might have something to do with it ive a set of 18's on it any help would be gratefull
Old Sep 11, 2005 | 05:45 PM
jaiscossie's Avatar
jaiscossie
i got this same problem as mine came on today and stays on now
Old Sep 11, 2005 | 06:37 PM
Dave McB's Avatar
Dave McB
get the WD40 out and spray the back of the wheels with it......worked for mines
Old Sep 13, 2005 | 10:27 AM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
check your fluid levels too,s2s lights come on early!
maybe best to check your brakes proper,spraying wd40 may contaminate your pads,and cause slippage
after all,they stop your car!
Old Sep 13, 2005 | 10:51 AM
mart.rs's Avatar
mart.rs
have a look at the the casing where the two sensors sit(one at the front and one at the back, all you gotta do to make the light go out is to get the sensor and hold the clip in then just put some tape around it to stop it from not touching,do the same with the other one and bob your uncle! od you could do what ive done and just diconnect the whole lot because it dont work anyway as any modded s2 ownwer will tell you, get an xr3i master cylinder,then just remove the remaining pipes!!
Old Sep 13, 2005 | 06:54 PM
akito-man's Avatar
akito-man
speaking for esc s2 s that is,
but better get your system checked for your coz mate.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
