why dont my cosworth 4x4 brakes fit on my 4x4 dohc
Hi, ive been doing up a sierra sapphire 4x4 with a 2dohc engine in it. it needed new discs and brake pads all around so I baught a set of 4x4 cosworth ones as i was told they would fit.
however when i went to fit the pads i noticed that the calipers were slightly too small for them so i got a set of calipers to fit the pads. i then found the calipers didnt fit the hubs!
Luckyily I already had a set of 4x4 hubs so ive fitted these along with new cosworth 4x4 TCAs and bushes. Now ive found that the TCAs wont reach the anti roll bar and the and crossmember at the same time
Im hoping that the Anti roll bar is all ill have to change to make it all fit together can anyone confirm this or does anyone know if the xmembers are diferent?
Thanks, Steve.
.Luckyily I already had a set of 4x4 hubs so ive fitted these along with new cosworth 4x4 TCAs and bushes. Now ive found that the TCAs wont reach the anti roll bar and the and crossmember at the same time
Thanks, Steve.
Cossie ARBs spring open a lot mate. They are a pain in the arse.
I always ratchet strap the ARB to pull it in a lot.
Try fitting the ARB off a Cossie but you will still have to put a lot of effort into getting the TCA inner bolts in with the ARB attached to the TCAs.
jason_nike
Aug 18, 2019 10:53 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
