2wd TPS vs 4wd TPS...
Old Sep 2, 2005 | 03:56 PM
2wd's Avatar
2wd
Default 2wd TPS vs 4wd TPS...
HI , just want to ask if anyone know if tis possible to make a 2wd TPS work on a 4wd engine ???
Old Sep 2, 2005 | 04:06 PM
Dave Henshall's Avatar
Dave Henshall
yep, seamless as long as you use a 2wd loom and ecu
for teh sake of 70 quid, get a new 4x4 one, then you know its right as swapping wires round and messing about will always need undoing when it need replacing and u can only get a 4x4 one
Old Sep 2, 2005 | 04:27 PM
2wd's Avatar
2wd
Hmmm...I have a complete 4wd engine with L8 and loom and so on.
problem is that I have ordered a 4x4 one but as I understand they are in back order so I dont know when I will have it....and as I'm in the middle of running in my new engine I cant wait, but its a pain driving it right now...
By the way is it normal that my clutch (AP six padle with std cover) when I start from a standstill it shakes a fair bit ??
Old Sep 2, 2005 | 08:21 PM
richm's Avatar
richm
no. you can't use a 2wd TPS on a 4x4 ECU, the characteristics are very different even with the wires swapped over on the TPS connector. The TPS and ECU need to match to work properly.
Old Sep 3, 2005 | 01:00 PM
2wd's Avatar
2wd
Thanks
so if I put on the L6 ECU and the 2wd TPS....would that work on the 4wd wiring...if wires need changing...wich ones ?
Old Sep 3, 2005 | 01:01 PM
Dave Henshall
did you have the flywheel skimmed bfore fitting the 6 paddle?
chances are it will get better with use, but with a paddle it really needs smooth faces on both the cover and flywheel to work nicely.
i think msd have pf09 (4x4) tps in stock....
ps, bont be fooled by the colour either, there are both red and black 2d and 4x4 ones about, its the part number that maters,
PF09 4x4
PF01 2wd.
Old Sep 3, 2005 | 02:37 PM
davidreader5's Avatar
davidreader5
HI,
Yes should work using 2wd, switch and l6, with 4/4 loom, reverse pins 11, 30. as 4/4, switch with 4/4 ecu. and 2wd loom swop over pins
11&30.
DAVE R.
Old Sep 4, 2005 | 10:04 AM
2wd's Avatar
2wd
i think MSD have pf09 (4x4) tps in stock....
PF09 4x4
PF01 2wd.
Hmm..I have a brand new flywheel and cluch/cover........so...?
Well they have pulled money for the TPS from my acount , so I have to wait
Thanks for all the answers, but It seems there are different opinions about the 2wd/4wd TPS connections....witch one is correct..???
Old Sep 4, 2005 | 11:14 AM
Dave Henshall
the 2 will work mid throttle as then it is only a reistance input, but at idle the car may not run right,
some tend to oversimplify ... as the spec is 0-5v 4x4 and 5-0v 2wd, so just swapping the outer 2 wires will reverse the action, maybe, but im not 100% convinced
Old Sep 4, 2005 | 12:03 PM
richm's Avatar
richm
yes, idle and light-load driveability will be poor with the wrong one. Trying to use a 2wd (PF01) TPS on a L8 ECU WILL give you grief, just not worth it IMO evan as a stop-gap
Old Sep 4, 2005 | 03:38 PM
davidreader5
HI,
USE THE CORRECT SWITCH WITH CORRECT ECU, PFO9=4/4,L8,
PFO1=L6, 2WD.
DAVE R
Old Sep 4, 2005 | 05:46 PM
2wd's Avatar
2wd
Originally Posted by davidreader5
HI,
11&30.
DAVE R.
So in my case (4wd loom and L6 ECU + 2wd PF01 TPS) I will have to switch over pin 11 and 30.......correct ?
Old Sep 4, 2005 | 05:51 PM
Dave Henshall
i think so....
Old Sep 4, 2005 | 07:03 PM
richm's Avatar
richm
HI,
11&30.
DAVE R.
Yes.
Old Sep 4, 2005 | 07:31 PM
CosRush's Avatar
CosRush
Just to add something though...
I seem to remember my Weber Marelli technical data on the system actually says you can swap the wires between the two for use on the L6 and the L8 IFRC....
I'll dig it out if its any use....
Old Sep 6, 2005 | 12:56 PM
2wd's Avatar
2wd
Thanks to all
If its not a prob. I would like to see it...
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
focus2351
Sep 9, 2015 09:33 PM
