Miss Fire On Boost
Hello guys my car has developed a miss fire when its in boost, The miss fire went away for a few secs but came back!!
I have changed the leads, plugs, coil, dist cap, but NOT the rotor arm as they didnt have any in at the time.
But it still has a miss fire. I took out the spark plugs and checked that they were all sparking and they seem to be.
Anyone got any ideas?
Also if i put the ignition on so that i can check the coil with a volt meter, The two thin wires going in to the coil what readings should I get on my meter?
I NEED HELP!!!!
CHEERS Guys
I NEED HELP!!!!
CHEERS Guys
I had same problem i changed loads bits even went in to garage and they said it was under fueling.was not that in end turned out to be a worn tappet i changed it and it was ok for a little while but broke tappet again so ive now got a new cam and tappetes an its fine...might not be same for yours but it fixed mine....
Just changed the tappets!! Bloody xpensive!! 14notes each!!!!!!! Anyway, it made no difference!, Anyone got any other ideas?
Its got two fuel pumps, and a swirl pot, Any idea how I check if these are working correctly?
When the car is runing you can hear the fuel pumps tick, But sometimes they stop ticking and then start again. I hate this car!!!!!!
How do you think fuel pressure?
Cheers Guys for all your help!!!!
I just had a look at that valve, It has 3pipes going in to it, and two wires. If i just removed the wires and taped them up, Would the car still run?
I also did a search for amal valve, Not many people just disconnecting them, they all seem to fit a bleed valve was that what you were meaning KSA-Cossie? Im kind of lost now!!!!!
Its still miss fireing, I dont have a bleed valve I will see if I can get one tomorrow.
On a bleed valve the two from the acuator and the comp join but doesnt one go to the fuel metering unit?
Cheers for all the help guys
grimmeRST, What do you mean blank it off? Do you mean join the two pipes togather that go to the acuator and the turbo? and just blank off the fuel metering unit by its self?
Or individually so none of them are joined?
thanks!!!!!!!!!!
thanks!!!!!!!!!!
right guys, I just took the amal valve out, it made some difference, I blanked off all the 3 pipes, but i didnt join the two from the comp and the acuator togather I indivdually blacked them all off.
Before the boost wouldnt go past 10psi because it used to missfire, Now for some reason it goes to atleast 22psi before it starts to missfire. And im sure the car was only set at 19psi maybe thats over boost? Im not sure.
I changed the fuel pump relay also.
The plug gap was at 0.6, but i made them smaller down to .55 incase it was getting blown out.
just put the bleedvalve from the actuator pipe and the compressor housing pipe and blank the one what comes from the metering unit.
could of been overboost at 22psi, some chips are 20 psi cuts,
disconnect the electrical wire going to the amalvalve aswell.
Alright guys, I fitted a bleed valve to my car, I made it so it wasnt boosting as much as it used to but it still has a miss fire.
Now would having low power in the battery make it have a miss fire? as thats the only thing I havint changed yet!!!
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
