Converting Mfi to Efi
Old Aug 31, 2005 | 08:52 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Converting Mfi to Efi
any one know exactly what is involved in converting a MFi turbo to run Efi turbo. also any one know were to get all the parts from, many thanks Bri.
Old Aug 31, 2005 | 09:28 PM
biggy_j's Avatar
biggy_j
hi mate there is a guide in this months performance ford.
Old Sep 1, 2005 | 10:31 PM
robert 123's Avatar
robert 123
WHAT MONTH MAG???? 08/05? OR 09/05 OR 10/05. I WISH TO DO THE SAME,HAVE ALL THE REQUIRED PARTS AND DONT KNOW WHERE TO START!!!!
Old Sep 1, 2005 | 10:39 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Ecu related MAP sensor. (OFAC ecu will need an OFAC MAP sensor) Fiesta turbo engine, or mixture of adapter plates and a hole drilled for the CPS EFi inlet manifold, throttle body and charge carrier ACT sensor, from the fiesta turbo Throttle body to charge carrier pipe, still available from Ford at the moment! EFi flywheel, Fiesta RS, XR2i, XR3i (EFi) XR3i EFi whole loom XR3i EFi Dash pod XR3i Throttle cable and pedal EDIS Module and coil pack etc from XR3i (or Fiesta RS)
taken from here
http://cruiseblackpool.co.uk/modules...article&sid=15
Old Sep 1, 2005 | 11:26 PM
CarlRsT's Avatar
CarlRsT
You go on cruiseblackpool Easiest option find a rear end write off Frst swap the lump and loom (or get a efi 3i loom) and get a 3i efi acl peddal as said above
Old Sep 2, 2005 | 04:45 AM
Wazzzer's Avatar
Wazzzer
you don't have to get EFi clocks, you can tap into a feed on one of the EDIS module wires to take care of that
once I've finished mine I'm gonna get together with Rab (if he wants to) and do a guide for it
Old Sep 2, 2005 | 05:23 PM
GrimmeRS2K's Avatar
GrimmeRS2K
na, just a google search mate, never heard of the site
steve.rst
Mar 15, 2016 08:01 AM
mondeomark
Sep 28, 2015 06:28 AM
dms04
Sep 11, 2015 01:57 PM
Neil Clark
Sep 8, 2015 07:06 PM
stevierob
Sep 7, 2015 07:09 PM
