does a 4wd rear caliper fir a 2wd car?
As my caliper is knackered ive been given on by a friend.... only thing is it is for a 4x4 will this fit my 2wd, they look the same.......
All Sierra rear calipers are the same, (GLS, XR4x4, 2wd Cossie) EXCEPT for 4x4 Cossie - as mentioned the 4x4 Cos caliper body is wider to accommodate the vented disc, so is not a direct fit as a replacement on a 2wd car with solid disc.
You can however fit all the 4x4 cossie parts together on a 2wd car, ie. calipers and vented discs.
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
