Starting prob on S2
Old Aug 31, 2005 | 07:56 PM
MAC30L's Avatar
MAC30L
Default Starting prob on S2
Hi folks, hope someone can give me a bit of help. My 90spec RST is somestime struggling to start within 2 or 3 seconds of the key being turned. Sometimes she will burst into life - other times it needs turned over for about 10s before going. Its a bit of an intermitant problem really. The car is totally standard appart from a mongoose. Got 63k on the clock and made 121bhp at the wheels last week at 7psi. The guys at the rollers (AVA - Glasgow), said the car was spot on appart from this wee starting problem! Any ideas on what to check?
The fuel preasure is ok (checked at the rolling road set up), the battary is strong, the starter turns spot on, but just won't fire as it should, all the time. Just had a major service including belts, plugs, leads, head gasket, cap, arm etc etc, but still this problem is not solved.
Cheers,
Mac
Old Aug 31, 2005 | 10:20 PM
GrimmeRS2K's Avatar
GrimmeRS2K
sound like a fuel problem mate
fuel pump
disconnect the cold start valve and see what happens
Old Aug 31, 2005 | 11:00 PM
russel7.wanadoo.co.uk@fs's Avatar
mine was the same, if i leave the car for 2-3 days it starts soon as i touch the key, so i got some new injectors and now its fine,, the old injectors were leaking and flooding the engine and after 2-3 days it was all dry,,,,, hope this helps
Old Aug 31, 2005 | 11:30 PM
Shings's Avatar
Shings
Could be a million things.....
Worn bottom end- and yes even at that milage it is possible...
Best get it into your tuner to sort
Old Sep 1, 2005 | 06:08 PM
MAC30L's Avatar
MAC30L
where's the cold start valve exactly mate?
I am 99% sure it is a fuel problem.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
gcfcos
88
Sep 15, 2015 03:48 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
