Zetec Sierra
Old Jun 29, 2004 | 09:30 PM
James's Avatar
James
Default Zetec Sierra
Will a Zetec lump go in a 1.8 CVH sierra? If i got an adapter plate it would run on a carb wouldn't it?
Old Jun 29, 2004 | 09:32 PM
Jim Galbally's Avatar
Jim Galbally
people bung em in mk1/2 escorts so i see no reason it wouldnt fit in a sierra
you'd probably need the same kinda conversion bits the oldskool people use, like the remote thermostat housing n stuff n adapters for the gearbox n stuff...
have a look in the burtons catalog for most of these bits
Old Jun 29, 2004 | 09:45 PM
James's Avatar
James
Surely i could just use the cvh flywheel/clutch?
Old Jun 29, 2004 | 11:33 PM
M Brian's Avatar
M Brian
what you mean james?
what jim is saying is that on the zetec the stat and everything is at the wrong end for RWD and it will be in the bulk head - so there is a kit to remote locate it so this doesnt happen... also the pipes for the rad etc come from the back.
the clutch and lfywheel would be ok from the zetec i would of thought.
note sure how the engine mounts work either mind
Old Jun 30, 2004 | 12:54 AM
Project ST's Avatar
Project ST
If the Sierra and Escort CVH flywheels are the same (clutch bolts on in the same way on both) then the Zetec flywheel and clutch will be fine.
/Monk
Old Jun 30, 2004 | 07:09 PM
James's Avatar
James
Sorry ignore me...
I was looking in the burtons book who list Zetec flywheels for RWD use..
Just thinking out loud really.. To much hassle really.. get a 2.9 and be done with it me thinks
RB26DETT
Feb 5, 2022 01:54 PM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
