could i bodge it or should i not bother
Old Jun 29, 2004 | 09:26 PM
escort1989uk's Avatar
escort1989uk
Default could i bodge it or should i not bother
was pondering the idea of using a cossie twin fan set up on the s2 erst what do you think would it be worth it and would it fit has it been done before thought about using a different thermostat as well so fans cut in earlier what do you peeps think
Old Jun 29, 2004 | 09:31 PM
Jim Galbally's Avatar
Jim Galbally
the fans are larger than the radiator.
they cost similar money to aftermarket "proper" fans aswell
so IMHO i'd just fit a single decent aftermarket one...
also its the FAN SWITCH which makes the fans go on/off not the thermostat, a thermostat controls the flow of water to the radiator and all its there to do is make the car warm up quicker when started from cold (well, that and regulate a constant water temp for the engine... lol)
Old Jun 29, 2004 | 09:38 PM
GUZZLER's Avatar
GUZZLER
i'm quite impressed with that Jim.....
Old Jun 29, 2004 | 09:44 PM
Mark V8's Avatar
Mark V8
The cossie fans will only "suck" efficiently, so if there is not enough room between the turbo and Rad and you stick the fans in front of the radiator and reverse polarity they will be shite
Mark
Old Jun 29, 2004 | 10:32 PM
escort1989uk
tim to get some thin kenlowe fans and a alloy rad and intercooler and act guage then
Old Jun 29, 2004 | 10:39 PM
Ryan's Avatar
Ryan
i got some cossy fans you can have cheap if you wish to try
Old Jun 29, 2004 | 10:42 PM
escort1989uk
cheers was just wondering so changed my mind
Old Jun 30, 2004 | 04:06 AM
Wazzzer's Avatar
Wazzzer
I'm sure someone off here said about putting a Cossie fan switch in the RST housing to make the fans come on sooner, is this possible?
Old Jun 30, 2004 | 01:06 PM
Wazzzer's Avatar
Wazzzer
Old Jun 30, 2004 | 04:30 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
yes u can use a cossie fan switch so the fans come in at a lower temp on RS turbos. i stuck an XR2 fan switch in mine cos i needed one and i had a new XR2 one lying their and fan comes in just a bollock hair over quarter
little bram
Oct 4, 2015 12:13 AM
It's Czech Mate
18
Sep 8, 2015 07:47 PM
Aug 31, 2015 11:02 AM
Harryh24
23
Aug 24, 2015 09:07 AM
Harryh24
Aug 11, 2015 07:48 PM
