settle an argument??
Old Aug 26, 2005 | 11:23 PM
Combi_Chris's Avatar
Combi_Chris
Default settle an argument??
please will someone explain dump valves , and why they are of NO advantage to an escort rst , and why some cars do run better with them ??
inc reciculating ones
thanks
Old Aug 27, 2005 | 09:00 AM
GrimmeRS2K's Avatar
GrimmeRS2K
i think its just a personal choice on a erst, but it does cause a few running problems on a mfi rst
if i had efi, there wouldnt be any dumpvalve on my car, chatter all the way!
Old Aug 27, 2005 | 10:54 AM
antony215's Avatar
antony215
Escort Rs Turbo
This is what i read about dumpvalves-----
Although a dump valve in itself will not increase power it reduces the effects of turbo lag between gears. When the turbo has fully spun up and is pushing its maximum boost to the engine when the throttle is closed during a gear change the turbo will start to push against a dead end. This causes the turbo impeller to loose revs and spin down. When the next gear is selected and the throttle again opened the turbo will need to spin up to its boost pressure again. By fitting a dump valve the turbo can keep spinning since the valve is releasing the built up pressure to atmosphere. This hence reduces the lag of the turbocharger and allows the power in the next gear to come in much quicker. Note: During very severe driving and higher boost pressure the dead end effect of a closed throttle can cause the turbo impeller to shatter due to the high pressure it creates.
So i would think they help in someway.
Old Aug 27, 2005 | 11:06 AM
MadMac's Avatar
MadMac
All the above as antony215, says.
However it is just a personal choice. and unless your running a car with 40+psi of boost, there aint much chance of the impeller shattering.
Dump valves are also supposed to prolong the life of a turbo. But again unless your running a lot of boost, dont make much difference.
At the end of the day most people fit them cus they want the phist sound.
Old Aug 27, 2005 | 11:18 AM
antony215's Avatar
antony215
Escort Rs Turbo
MadMac,
Thats what i think just there to get you noticed half the time
Old Aug 27, 2005 | 11:32 AM
MadMac's Avatar
MadMac
thats the one.
However I'd rather convert my car to EFI and have chatter
Old Aug 27, 2005 | 11:33 AM
antony215's Avatar
antony215
Escort Rs Turbo
MadMac,
Old Aug 27, 2005 | 12:16 PM
addiction's Avatar
addiction
also it puts extra pressure on the bearing inside the turbo,a standard bearing only operates on 180 degree of the face,this is why hybrid turbo's have a 360 degree thrust bearing to cope with the back pressure!
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
pabloXR
Sep 21, 2015 12:42 PM
121
Feb 4, 2005 01:04 PM
pugo
Jan 15, 2005 08:40 PM
