meatering head chattering ??
Old Aug 25, 2005 | 07:30 AM
D_a-RR-e_N's Avatar
D_a-RR-e_N
Default meatering head chattering ??
hiya is it possible anyone can give me any advice?? just had a 2l zvh build and is now in my mk3 cabby, having starting problems all the time with it, and when it does start it seems very slow to pick the revs up and when hitting about 5000 revs u back off and the meatering head flap chatters ? is this loss of fuel presser or something along them lines ?? any one had this problem b4 ??
thanks guys
Old Aug 25, 2005 | 02:22 PM
turbo7's Avatar
turbo7
From: southend on sea bruv under that fu##ing car bonnet
think it might be something else as the metering head flap chattered on my mates turbo and that was runnin fine at the time,,
Old Aug 25, 2005 | 06:19 PM
Turbo-T34's Avatar
Turbo-T34
got the same problem on my current RST (standard apart from exhaust and k&n filter), slow rev pickup from 1000-3000rpm, and get a lot of chatter, never had this on my last RST.
Old Aug 25, 2005 | 07:11 PM
D_a-RR-e_N's Avatar
D_a-RR-e_N
strange mine will not start of the key but it will if i tow it off ?? im just about to give up!! its a shame as well any one have any other ideas ?
thanks guys
Old Aug 25, 2005 | 07:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Dodgy fuel pump m8 my old s2 did that.
Old Aug 26, 2005 | 07:23 AM
D_a-RR-e_N's Avatar
D_a-RR-e_N
ok ill try put a new pump on it cheers
Old Aug 26, 2005 | 11:25 AM
adamS2RST's Avatar
adamS2RST
Boost leak? Mine chats a bit, and I suspect may be a boost leak, either that or the turbo is on the way out.
Old Aug 26, 2005 | 07:45 PM
D_a-RR-e_N's Avatar
D_a-RR-e_N
took compresser housing off tonight and didnt have a rubber seal on it would this becausing it not to start of the key and when it bumps off chatter?
cheers guys
Old Aug 29, 2005 | 07:27 AM
D_a-RR-e_N's Avatar
D_a-RR-e_N
car still isnt running, it doesnt seem to be pulling the plate down enuff of the meatering head any common problems on these? we have cheacked for any pipes split ect ect and theres no reason why it shouldnt run of the key any ideas?
Old Aug 29, 2005 | 10:45 AM
S1 JOHN's Avatar
S1 JOHN
my s1 used to do the non starting bit had something to do with the cold start valve over fuelling sometimes and then no fuel other times re wired all the plugs on the back new sensors and new cold start injector
Old Sep 2, 2005 | 01:12 AM
D_a-RR-e_N's Avatar
D_a-RR-e_N
took the flap of the meateringhead and theres puddles of fuel there :S cant be good so going to try a new meatering head see how that goes thans for all your help guys.
Old Sep 2, 2005 | 10:38 AM
mart.rs's Avatar
mart.rs
Why not just scrapp the metering head anyway,and go for efi ive heard you get good results!
Old Sep 3, 2005 | 10:56 PM
Series 1 van's Avatar
Series 1 van
myines chatters on my van my mate gavintwopies says its the spring on my van dump valves too hard sounds mint tho love it
Old Sep 4, 2005 | 11:53 PM
D_a-RR-e_N's Avatar
D_a-RR-e_N
yeah thinking of going EFI just means scraping 3 month of hard planin on this set up lol
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
