help me fit my turbo please!
i am on fitting a t34 turbo to my 2wd saff cos and im puzzled on how do you get the bracket which holds the turbo damper, off the wastegate?
Originally Posted by Chris Honeywell
M8 you mean the centre ring with the hole in it right if so don't your t34 have one already??...
if not then is the t34 u got for a 4wd manifold?
post up a pic
post up a pic
to remove the one of your standard old turbo just undo all the 13mm bolts around the hsing and rotate hsing and it will slip off! you will also have to make a bracket for the actuator and rotate the hsing to suit!
i had orderd a t34 for my saff and the place i got it from forgot to put the turbo damper bracket on iv rang them and they are sending me a bracket.Thanx for your help folks
marky_g
Aug 15, 2015 10:43 AM
