Engine stalls
Old Aug 24, 2005 | 11:30 AM
Jo's Avatar
Jo
Default Engine stalls
Noticed something today, when I pull out the oil dipstick of my ERST while the engine is running, it wants to stall. As soon as I put the dipstick back she runs normal again. What does that mean? Worn engine?
Old Aug 24, 2005 | 12:07 PM
Combi_Chris's Avatar
Combi_Chris
my car does the same when i remove the oil filler cap , and so did all my other rst`s , i dont think you have a need to worry , unless your having trouble under normal driving conditions ?
Old Aug 24, 2005 | 12:13 PM
Jo's Avatar
Jo
there are no trouble at all under driving conditions.
I also noticed there is an oil leak through the dizzy. I've heard this is a common problem on CVH engines, is that true?
Old Aug 24, 2005 | 12:36 PM
thepigfarmer's Avatar
thepigfarmer
Default Re: Engine stalls
It will try and stall as its losing compression, so nothing to worry about
Sounds like ur Dizzy is cracked and needs replacing
Old Aug 24, 2005 | 04:38 PM
addiction's Avatar
addiction
nothing at all to worry about because they all do it. the engines need to be airtight and any break in the seal will result in,rough idling,stalling and non starting
The Enigma
13
Aug 20, 2015 09:38 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
