boost prob???????
Old Aug 23, 2005 | 12:49 PM
rsbabe666's Avatar
rsbabe666
Default boost prob???????
i done a engine change but didnt now where one of the pipes go from the turbo now my car is over boosting and i cant boot it please help
Old Aug 23, 2005 | 01:26 PM
Lemon S2's Avatar
Lemon S2
Sounds like its the one that goes to the Amal Valve but can't remember what order they go in. Some one else should know the order. One goes to the Air flow meter, one goes to the turbo & the last one goes to the actuator
Old Aug 23, 2005 | 02:02 PM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like the pipe that comes from the tubo to the amal valve There are three pipes which attach to the Amal valve, each pipe is marked by a letter on the Amal valve, C(middle) comes from the turbo housing, W(top) goes to the actuator, R(bottom) goes to the airbox hope this helps
Old Aug 23, 2005 | 02:14 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
RS babe huh
Old Aug 23, 2005 | 02:21 PM
rsbabe666's Avatar
rsbabe666
where would i find the amal valve is it the one the bleed valve sits in between?
Old Aug 23, 2005 | 02:24 PM
antony215's Avatar
antony215
Escort Rs Turbo
Its on top of the gearbox
Old Aug 23, 2005 | 03:41 PM
rsbabe666's Avatar
rsbabe666
ok thank you!!!!!!! keep you posted on progress!
Old Aug 23, 2005 | 03:58 PM
rsbabe666's Avatar
rsbabe666
had a look and found another smaller pipe about half a foot long which is in between the bottom pipe which goes to the intercooler and the top pipe which goe to the air filter..... this is the pipe which i dont know about????? any ideas
Old Aug 23, 2005 | 05:43 PM
DazC's Avatar
DazC
RS babe huh
Dave, back off you letch!!!
She is about 450 miles away from you anyway!!
Old Aug 23, 2005 | 05:50 PM
DazC's Avatar
DazC
RS babe,
You should have 2 pipes coming off your turbo, one off the compressor housing and one off the actuator. they should both go to a valve on top of the gearbox which has 3 ports on it (amal valve). On the amak valve there is 3 ports labelled up as such...
C which needs the pipe to the compressor housing on it
W which needs the pipe to the wastegate actuator on it
R which needs a return pipe to the fuel metering unit on it.
The bleed valve should REPLACE the amal valve and should have 3 ports on it otherwise it will cause runing problems...
Hope that helps.
Old Aug 23, 2005 | 08:44 PM
Robliddle's Avatar
Robliddle
Quick question while your on the subject of amal valves!
should they be fixed to the gear box with a bracket or something? because mine just hangs on the end of the three pipes and bangs about under the bonnet?
Old Aug 24, 2005 | 08:41 AM
antony215's Avatar
antony215
Escort Rs Turbo
Robliddle,
Should be held on with a bracket
Old Aug 24, 2005 | 09:14 AM
antony215's Avatar
antony215
Escort Rs Turbo
rsbabe666,
You should have two large pipes that come off your turbo ONE FROM THE BOTTOM OF THE COMPRESSOR HOUSING THAT GOES TO THE INTERCOOLER AND ANOTHER LARGE PIPE THAT COMES FROM THE MIDDLE OF THE TURBO THAT GOES TO THE AIR FLOW METER Then you have two small pipes ONE FROM THE COMPRESSOR HOUSING THAT ONE GOES TO (C) ON THE AMAL VALVE THEN ANOTHER SMALL PIPE THAT COMES FROM THE ACTUATOR THAT GOES TO (W) ON THE AMAL VALVE
Old Aug 24, 2005 | 02:18 PM
rsbabe666's Avatar
rsbabe666
ok figured it out last night after having a look at someone elses........
thanks alot babe! youve been a great help
shes running really well now!
Old Aug 24, 2005 | 03:00 PM
antony215's Avatar
antony215
Escort Rs Turbo
Good to here you got it running right
Old Aug 25, 2005 | 07:41 AM
rsbabe666's Avatar
rsbabe666
thanks once again!!!!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
