4x4 ESCORT COSWORTH WATER PUMP
HI ALL
ANY EVER FITTED A WATER PUMP TO ESCORT COSWORTH SMALL TURBO IS THERE MUCH INVOLVED & COULD YOU EXPLAIN HOW TO CHANGE IT
ANY HELP WOULD BE MUCH APPRECATED
CHEERS PAUL
CHEERS PAUL
I assume its the same as the 4x4 saf etc
1. loosen 4 bolts on water pump pulley
2. remove both alternator belts
3. take pulley off
4 loosen all bolts and hoses, drain water system and remove pump
5. put new pump on using appropriate gasket and a very small amount of gasket seal
6 do steps 4, 3 2 then 1 in reverse
7 fill cooling system
3. take pulley off
jessie_rs
11
Jun 3, 2019 04:57 PM
