what lamda sensor...
Old Jun 28, 2004 | 10:16 PM
xrsi's Avatar
xrsi
Default what lamda sensor...
am waiting for my phantom AFR gauge to be delivered and had a couple of thoughts...
was just wandering how i will go about getting a lamda sensor put into the downpipe of a stainless system and also what one to use? should i use a specific one for that gauge or any 2/4 wire type?
Old Jun 29, 2004 | 09:37 AM
AustenW's Avatar
AustenW
The gauge will need the specific wide band lambda for it as they all work slightly different.
4 wire work differently to 5 wire and require a separate controller.
You can get hold of lambda nuts from your local tuner. (same thread as a spark plug I think)
Just a case of welding it at a 90 deg horizontal angle to your downpipe.
Old Jun 29, 2004 | 09:50 AM
zvhturbo's Avatar
zvhturbo
Is your guage for a wide band or a narrow band mate??
Wide bands need seperate controllers and you must use the right sensor.
Narrowbands can use almost anymake of sensor as long as its the correct type
Check out www.turbobits.co.uk
and www.tuneparts.com (bottom left of home page click on "Just Lambda"
A 4 wire sensor has a built in heater and is slightly more accurate.
Matt.
P.S. bast ask the guage manufacturer what sensor they recommend
Old Jun 29, 2004 | 10:06 AM
CraigN's Avatar
CraigN
well i presume hes talking about autometerr phantom gauges which will mean narrowband
i use a mk4 fiesta zetec one on mine
4 wire has built in heater
Thanasis
Apr 3, 2007 03:14 PM
Mike Rainbird
66
Dec 7, 2006 01:53 PM
rs cos
Jan 9, 2006 10:52 PM
18
Sep 30, 2005 12:17 PM
georgie1
Ford Escort RS Cosworth
Mar 22, 2005 08:54 PM
