ERST water pump............... WTF???
Old Jun 28, 2004 | 09:17 PM
McPikie's Avatar
McPikie
Default ERST water pump............... WTF???
Having stripped the cab down last week I noticed it has a water pump that I have never seen before.
If you are looking at the block from the slam panel, the pump comes out towards you, but then has another pipe that comes off towards the right hand side. This was blocked off with a bit of hose and a jubliee clip but will it run right when put back together??
Old Jun 28, 2004 | 09:27 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Sounds like a Series one pump?
Old Jun 28, 2004 | 09:37 PM
dave green's Avatar
dave green
Some of the early ones were like that, or as the post above
Old Jun 28, 2004 | 09:39 PM
McPikie's Avatar
McPikie
It has a series 1 box in it as well but has a knock sensor on the inlet.
Sounds like its a cobbled together piece of shite
Old Jun 28, 2004 | 09:42 PM
DazC's Avatar
DazC
Does it look like the pump on the front of this....If so then it is an S1 pump.
https://passionford.com/forum/viewtopic.php?t=59211
Old Jun 28, 2004 | 09:44 PM
McPikie's Avatar
McPikie
Thats the bad boy Nice one Daz
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
