head trouble
Old Aug 21, 2005 | 03:24 PM
craig b's Avatar
craig b
Default head trouble
ive replaced the cam and hydralics tappets in a s2 rs turbo the cars standard but it starts ticking after 2000 mile the cam i took out wernt dat old and the lobes were wore so i replaced it but now the new one as gone like it. cheers 4 any help also is the turbo 16 cvh head the same as a standard cvh head?
Old Aug 21, 2005 | 03:35 PM
Oranoco's Avatar
Oranoco
Don't think there is much difference between the 3i head and the Turbo one iirc. Did you run the new cam in properly?
Old Aug 21, 2005 | 05:57 PM
craig b's Avatar
craig b
it was out a xr2 the cam was but it looked good i held the car on around 3ooo revs for about 15 - 20 mins
Old Aug 22, 2005 | 01:59 AM
gavintwopies's Avatar
gavintwopies
Are you sure that the oil is getting up to the top end as a mate of mines xr2 turbo was scranning cams for fun 1 every fortnight turned out main bearings were worn and reducing the pressure to the top end , hence increasing the cam wear and shortening the life of them
Old Aug 27, 2005 | 06:33 PM
craig b's Avatar
craig b
the engine had a full rebuild and the main bearings got changed i was thinking a oil port is blocked which aint getting the oil up cheers for the help thou
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
