Noisey 4x4 Engine - Poss rebuild help
Old Aug 21, 2005 | 12:47 AM
FingerZ!'s Avatar
FingerZ!
Default Noisey 4x4 Engine - Poss rebuild help
I have a 4x4 saph which runs n drives pretty good.
Me missus took it out today and when she rolled up after a little boost i thort i eard it rattle as it turned the corner slowing down.....
SO checked oil - was on low - topped up to max - thort all would be well.....
later tonight - got me mate to drive towards me on boost so i could hear over the induction whatever noises the engine makes.....it makes a kind of growly rattle as it boost kinda top end noise - does this sound like its engine rebuild time to you guys???
If it is engine rebuild time, im not interested in a balls-out performance rebuild, i would be happy with a standard rebuild as i want to run approx 18psi boost, sometimes more at a push. Surely a standard build will be enough to last me abotu 30k miles and if so, what does anyone think the cost of a standard build would be??
I am a mechanic and can source all the parts needed, can remove and strip engine ready for engineering <re-bore, shells, crank grind etc if needed> so the costs of removal and refitting engine is not a problem.
cheers
Tim
big_Rad
Sep 15, 2017 09:36 AM
Wilsfoci
15
Mar 30, 2016 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
Old ford
Jul 31, 2015 06:50 AM
