lsd test
Old Aug 19, 2005 | 10:59 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default lsd test
forgot how to test if the box has a lsd, i had a ib5 box installed the other week and asked them to include the lsd in the ib5 box
is there a way of testing with both wheels jacked up and turning one and the other side turns aswell
i engaged 1st gear, jacked up, and turned the passengers side wheel and the drivers side did turn aswell, but not in netruel,
have i been ripped off?
Old Aug 20, 2005 | 12:54 AM
NUTS RuS's Avatar
NUTS RuS
Wheels should turn in opposite directions
Old Aug 20, 2005 | 08:59 AM
cuvner's Avatar
cuvner
wheels should turn in same direction in neutral, they turn in oppostie directions wen its a slip diff! Just looked on another site to confirm this!!
Old Aug 20, 2005 | 09:14 AM
NUTS RuS's Avatar
NUTS RuS
And cuvner ~ LSD stands for ?? As the title says LSD test.
Old Aug 20, 2005 | 09:21 AM
cuvner's Avatar
cuvner
bit confused
lsd(limited slip)- wheels turn same direction
normal dif-opposite wheel slips but will turn in opposite direction?
Old Aug 20, 2005 | 09:33 AM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
Originally Posted by cuvner
bit confused
same here
my rs box gave up (deffo lsd) they go same way when in nuetral
i fitted a xr2 box in its place and they go opposite ways
if u do have a shaft out then u look thru the diff and if u see a hole its non lsd, if u see a shaft running across the hole then its lsd
Old Aug 20, 2005 | 09:39 AM
GrimmeRS2K's Avatar
GrimmeRS2K
the other wheel didnt even move in nuetral!!
Old Aug 20, 2005 | 09:43 AM
1.9 xr2 on 40's
st170 breaking
hmm simons box did that on his 1.3 but was cos shaft was fooked
it drive nice? or pull u about over the rd?
could do a smokey rolling burnout and see if both wheels lay a slug
Old Aug 20, 2005 | 09:55 AM
GrimmeRS2K's Avatar
GrimmeRS2K
it drives ok, think it needs a cv joint on the drivers side, but everything else is new!
it does pull to the side when the boost spikes! though, but it always done that!
in 1st gear the other wheel went in the opposite direction
Old Aug 20, 2005 | 09:58 AM
1.9 xr2 on 40's
st170 breaking
ohh dear
i dunno then
got any pics of the instalation??
Old Aug 20, 2005 | 10:03 AM
GrimmeRS2K's Avatar
GrimmeRS2K
na no pics. gearbox centre in caister done it, he say that he would put the lsd in, but im doubtfull
Old Aug 20, 2005 | 11:13 AM
Combi_Chris's Avatar
Combi_Chris
lsd means limeted slip differential
Old Aug 20, 2005 | 12:05 PM
1.9 xr2 on 40's
st170 breaking
enlightened us all now
Old Aug 20, 2005 | 12:15 PM
James Raby's Avatar
James Raby
PMSL
Old Aug 20, 2005 | 12:38 PM
Wazzzer's Avatar
Wazzzer
just pull the shaft out the box and have a look at the diff then you'll defo know
Old Aug 20, 2005 | 03:49 PM
NUTS RuS's Avatar
NUTS RuS
In neutral mine rotate the same way, in gear opposite ways.
A torque biasing diff may not rotate the other wheel in neutral as it relies upon torque (obviously)
Old Aug 20, 2005 | 03:58 PM
GrimmeRS2K's Avatar
GrimmeRS2K
oh right, havent got the time to pull the shafts out, so do it looks like i have one before i go there and kick off!
Old Aug 20, 2005 | 04:07 PM
NUTS RuS's Avatar
NUTS RuS
yep - at a guess
Old Aug 20, 2005 | 04:12 PM
GrimmeRS2K's Avatar
GrimmeRS2K
cheers mate, im sure something will break soon, so next time im under the car, ill pull the shafts out and confirm
Old Aug 20, 2005 | 04:18 PM
NUTS RuS's Avatar
NUTS RuS
Thats positive thinking for you
Old Aug 21, 2005 | 03:42 PM
JesseT's Avatar
JesseT
You all sound so confusing with the opposite/same rotation discussion. Just jack up one wheel and select neutral. Then rotate the wheel. You cna deffo feel the difference. With a normal diff you can give the wheel more and more speed whereas with a LSD you can only rotate it very slowly at ~3s per revolution max.
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
