Can you adjust the clutch cable S2?
Guess i should know this
but is it possible to adjust the clutch
cable on a series 2?
Having a bit of trouble selecting gear since the engine has gone back in.
The clutch pedal has to be pushed right to the very bottom to be able to get gears,even then some times it wont select.
Ive also fitted a B+M shifter,could this be anything to do with the problem?
Also does it matter which hole the cable is put through on the gear box
before it hooks onto the black arm?
there is no adjustment, is a rachett system on the pedal, it should adjust up on its own, could be fooked though!
didnt think it make much difference on the hole thing, as ive used both
Tried a new clutch cable?
my mate had a similar problem, and it was the release bearing not installed properly, or i think he may of bent it when putting the engine back in
release bearing not installed properly!?
fucking hope it isnt that
ive just had the same problem on mine
i changed the clutch,the clutch cable,and the box too,but no it was still there
until a technician at where i work suggested looking at the ratchet mechanisim and hey presto it was FOOKED!!! wasnt able to select gear at all for a about a year this went on all because of a Ł7.50 piece of plastic!
Check that the ratchet actually works and the pedal is pulling the cable from the very first milimeters of pedal movement.
You can get bigger size wheels for the ratchet to give more travel. They are colour coded.
You must use the correct hole for the cable depending on if oyu have the short or long arm fitted. AFAIK, only mk3s used a short one. The short one will gove more travel though.
If you have a AP-clutch or other heavy duty organic, then at least AP advises to fit the later escort pedal completely to avoid these problems.
the later escort pedal,does anyone know whats involved in doing this?
After recently having my engine rebuilt then reinstalled with a 6 paddle clutch I had a nightmare trying to change gear also.
To sort the problem my ratchet was replaced with an escort mark 5 fitting.
This web address should help if this is the case:
http://www.apracing.com/roadcar/clutch/epmods.htm
Mark
Mark
Mark
Mark
Cheers mate
There is a conversion that can be done that allows you to adjust it. I personally dont know how its done but my tuner does it and everyones thats had it done so far have said its great.
I too have just fitted the post 95 clutch pedal to my s2 this week just dont forget to cut the last 10 teeth off the ratchet otherwise you will have to do the job twice
The pedal travel is smooth and light with the ability too adjust the pedal travel from inside the car with a 6mm allen key which is a nice touch
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
muz
Sep 30, 2015 08:29 AM
