Adjustment screw on S2 Electro Magnetic Fuel Pressure Reg
Old Jun 28, 2004 | 12:05 PM
XRTypeRS's Avatar
XRTypeRS
Default Adjustment screw on S2 Electro Magnetic Fuel Pressure Reg
Which way do you turn it to either enrich or lean off? and how sensitive is it?, i.e. does half a turn make a big difference?.
Cheers,
Stuart
Old Jun 28, 2004 | 01:34 PM
XRTypeRS's Avatar
XRTypeRS
bttt
Old Jun 28, 2004 | 01:38 PM
RANJ's Avatar
RANJ
id be careful if ur unsure what u doin
Old Jun 28, 2004 | 01:39 PM
Ryan's Avatar
Ryan
if you not sure leave it!
too much the wrong way and BANG!
Old Jun 28, 2004 | 01:41 PM
Jim Galbally's Avatar
Jim Galbally
dunno about the EMPR but if perchance you mean the idle CO adjustment screw on the metering head then clockwise=rich and yes half a turn makes a BIG difference
Old Jun 28, 2004 | 01:49 PM
XRTypeRS's Avatar
XRTypeRS
No, I mean the black block on the side of the KE-JET meter head that controls your on boost fuelling (has a multiplug attached to it). When your having your car tuned on a RR this is what they take off and adjust (its just a small allen key adjustment).
Im not planning to mess with it but I just want to know so I understand what they do when they adjust it.
JK12
33
Apr 26, 2021 12:09 PM
yatta
May 21, 2016 10:31 PM
15
Oct 7, 2015 03:43 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
