rebuilding zetec
Old Aug 17, 2005 | 01:24 PM
demolition_man's Avatar
demolition_man
Default rebuilding zetec
Hi, i have a 2ltr zetec engine which for a variety of reasons has been stripped. I've decided to use this engine to try and start learning to re-build an engine.
Although i have the theory side sorted out, i know the practical side is going to be extremely tricky tolerances etc.
Basically i would like for you to post some general guidance for example "DON'T...... and "make sure you". Just things to look out for and things that i am likely to be unaware of. Any help is appreciated, i thought i may as well post before i start than break it and then ask!
I am definately going to do this, even if i bend a rod first time i start it, i want to get into it so its going to be done!
Thanks alot, Aid
Old Aug 24, 2005 | 09:56 PM
16vzetec's Avatar
16vzetec
timing is very important.
basically fit the whole lot including the belt but leave the cam wheels undone.
you will need a timing pin for the zetec which is put into the 10mm bolt hole at the front of the block.
a plate goes into the end of the cams and then you nip up the cam wheels.
you can do it by eye but its not so accurate.
when pistons 1 and 4 are fully up at 'top dead center' then you line the end of the cams up and tighten them up.
mk3ste
Oct 17, 2021 10:09 AM
bobsworth
77
Mar 24, 2016 09:30 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mc5506
Oct 5, 2015 09:57 PM
