Zetec Turbo???How the Fook!!!!!!!!!!!!!!!
Hi all, latest project RS1800 has fallen through as the shell was rotten,
now decided to reshell to an S2 shell
. Problem is that im addicted to boost and what to know how to turbo the zetec. Can it be done yourself or does anyone have a garage in the North West or North Wales to recommend.
Is this a DIY job
. Problem is that im addicted to boost and what to know how to turbo the zetec. Can it be done yourself or does anyone have a garage in the North West or North Wales to recommend.Is this a DIY job
it is a DIY job if you have time, money and some know how. Ideally, u should get the parts yourself and then give it all to someone else to assemble and setup. That's my opinion of what you "should" do. However i would try and do it myself then give it to someone with the equipment and skill to set it up fuelling etc. Whatever you feel your up to i suppose, many people have built themselves ZTs and the pool of knowledge is huge in the area which is always helpful. I'm rambling.
I have not long started the conversion to same spec engine it is quite easy conversion to do but it dose take time+money have a look at ZETECTURBO.CO.UK
one of the best guides about. Any other questions the people here should be able to help,tommy
2.0l mondeo lump
FRST ecu, loom and associated plugs / sensors
EFI flywheel with RST clutch
Vaux calibra turbo pistons ( give u 7.6 :1 comp ratio "ish")
Choice of inlet manifold i used Escort 1800 zetec one , 130ps throttle body is best )
exhaust manifold use RST and re drill / tap studs ( i welded a zetec flange to a RST manifold to retain zetec studs )
T34 turbo for deffo with a 55 or 63 housing , ( i have used a 48 but youll kick yourself that u didnt go bigger )
few other bits and bobs but thats essentially it , easy peasy , bit of work for myour locak macheinist and hey presto , 300 BHP and torque steer to die for ( or die from lol )
If u want any more info please feel free top call .
PS i have loads of spares from my build , T34 turbo , flu wheel ,spare engine , loom etc
