Bugger - had car booked in at ford...
Jun 28, 2004 | 10:16 AM
cos its making a noise, more so when turning left...
i replaced the n/s rear wheel bearing, and it still made the noise so i slung it at the ford monkeys.
they have just rang and told me its the n/s front wheel bearing - £130 all in
and, they also pointed out that my water pump is leaking, i know it was using water, so at least i know why now.
ive got a water pump at home thats pretty much new, they want £82 just to fit for "an hours work" fukk it, ill do it myself...
i really dont need this at the mo..
Jun 28, 2004 | 10:18 AM
Me Cossie Runs Atlast!!!!
Do the wheel bearing yourself mate or phone a local garage about it. They could do it for much cheaper im sure.
Jun 28, 2004 | 10:32 AM
£130 for a bearing
just take the spindle carrier off get a local garage to press the bearings in for 30 mins work and fit it all back yourself
Jun 28, 2004 | 10:35 AM
bit late now...
i told em to do it.
didnt think of just taking it a garge.
nay mind, i need the car anyway...
Jun 28, 2004 | 10:43 AM
Jun 28, 2004 | 12:14 PM
if the noise gets worse when turning left then it is normally the O/S bearing as the load transfers onto this side when making a left turn.
Jun 28, 2004 | 12:34 PM
oh, might be then, they are doing one of them anyway.
Jun 28, 2004 | 12:37 PM
Jun 28, 2004 | 12:46 PM
they said its the bearing
Jun 28, 2004 | 01:39 PM
my mechanic supplied and done both side front bearings for £80
Jun 28, 2004 | 01:40 PM
fukk sake, ford are charging £82 an hour labour
the coooonts!
fuzzy
Aug 9, 2015 09:43 AM
COLEYST200
Aug 3, 2015 08:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
